Old 30-12-2011, 09:58 AM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Question Computer Freezing problem
Hi All,
I was surfing websites then suddenly my desktop freeze.
mouse was not working (bcoz its LED lights went off)
keyboard keys were not working (so cudn't use task manager)
HDD LED was not blinking.
but all Fans(graphic card,proccy,PSU,extra Fans) were working as normal...
what could be the problem.
RAM or HDD?
Config: Core i5 750
4GB Corsair RAM
500GB WD Blue HDD
450VX Corsair
Gigabyte mobo P55
Windows 7 Ultimate x64
Old 30-12-2011, 10:59 AM   #2 (permalink)
CA50's Avatar
Default Re: Computer Freezing problem
Freezing problem can be due to many factors, HDD, PSU, RAM or it can happen because of windows itself.
Is that freezing frequent, if yes that might be because of some hardware , else t could be because of the windows.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 30-12-2011, 11:23 AM   #3 (permalink)
abhidev's Avatar
scan HDD for problems...
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is offline   Reply With Quote
Old 30-12-2011, 11:58 AM   #4 (permalink)
remove the Ram(s) and clean the gold pines gently with a eraser and blow some air over it with u mouth reinsert it and perform a Memtest 86+ for 2o mins atleast i highly doubt it the RAM. reply us the results as soon as u try it
hope that helps
Athlon II X4 640||GigaByte 78LMT-S2P||Corsair 4GB DDR3 1333Mhz+ 2GB EVM DDR3 1333Mhz||VIP 400watts PSU||Sapphire 5670 930/1020:P|| Philips 107E5 1280x1024 17''CRT|| Zebronics Bijli mod
http://www.hardfolding.com/fhtag.php...451114/1/4.png
Tarun is offline   Reply With Quote
Old 30-12-2011, 12:51 PM   #5 (permalink)
mithun_mrg's Avatar
I would suggest before doing anything scan the HDD's also try running live ubuntu & see if hangs there
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 30-12-2011, 01:59 PM   #6 (permalink)
Fullbring
Zangetsu's Avatar
I m also sure that its either HDD or RAM....
but if HDD has a problem...will it freeze the system & goes to off mode...
HDD doesn't have bad sectors...AFAIK
Old 30-12-2011, 02:15 PM   #7 (permalink)
CA50's Avatar
^ thats possible, IO error can led to system malfunction (crash and hang)
| Nokia 2700c |
Old 30-12-2011, 03:07 PM   #8 (permalink)
try putting in another PSU.Which one do u have currently ????
Old 30-12-2011, 03:41 PM   #9 (permalink)
Fullbring
Zangetsu's Avatar
^but after restart it works fine...
the freeze is intermittent
Corsair VX450
Old 30-12-2011, 03:46 PM   #10 (permalink)
CA50's Avatar
^ If its not frequent. then that might be due to some software issue as well.
It could even be because of some nasty virus. Wat AV are you using? Run a full system scan and check for any infection.
| Nokia 2700c |
Old 30-12-2011, 03:53 PM   #11 (permalink)
Fullbring
Zangetsu's Avatar
yes..but HDD going to sleep mode due to virus & software is surprising
I m using Bitdefender Internet Security 2012
Old 30-12-2011, 04:05 PM   #12 (permalink)
CA50's Avatar
^ your HDD maynot be sleeping
Just run a complete scan to be sure
| Nokia 2700c |
Old 30-12-2011, 04:19 PM   #13 (permalink)
★★★-DREADLORD-★★★
Skynaveen's Avatar
Can you restart.
If so when windows starts you will get a prompt saying that windows had some problem and then post the info on that dialog box here.
.Facebook vs Google Plus ----- poll/discussion (FIGHT CLUB)
http://www.thinkdigit.com/forum/figh...vs-google.html
Buying used or refurbished iPad: http://www.thinkdigit.com/forum/want...ml#post1615248
Skynaveen is offline   Reply With Quote
Old 31-12-2011, 09:28 PM   #14 (permalink)
Fullbring
Zangetsu's Avatar
The PC is working fine from last 2days...
but I have kept it under observation.
Old 01-01-2012, 09:43 AM   #15 (permalink)
CA50's Avatar
^ then the issue might be some software bugs or some windows (regular) issues
| Nokia 2700c |
- by kool
