I need a back up solution for my laptop. My laptop hard disk is 320GB so i will need a minimum 320GB capacity solution.
I don't have a budget for fancy external drives, is there any solution by which i can use cheap external hard disk and connect it with e-sata port of my laptop. All this at lowest possible budget.
