Hi
I previously have Dynet RAM which is 512 mb and i bought a new 1GB samsung RAM.
The problem is my old ram is 512mb ddr-400 and my new one is ddr-266.
Here is my pc wizard report about my motherboard please check out.
Ps: Please have a look at the end of my post.....
<<< Mainboard >>>
> Manufacturer : Unspecified
>> General Information
Product : Unspecified
Version : Unspecified
Serial Number : Unspecified
Unique ID : DA8C4328-EAED11DA-B77900E0-18874439
SKU : Unspecified
Family : Unspecified
Start mode : Power Switch
>> Chassis Information
Intrusion detected : Unspecified
> Mainboard : Intel D101GGC
>> General Information
Manufacturer : Intel Corporation (Intel)
Product : D101GGC
Version : AAD35788-308
Serial Number : BTGC621008A8
Support MP : Yes, 2 CPU(s)
Version MPS : 1.4
>> Chassis Information
Type : Desktop
Asset : Unspecified
>> OEM Support
HPET : No
SLIC : No
nVidia SLI Ready : No
>> On-Board Device Information
Embedded Controller : No
>> Slots Information
Slot PCI-Express : x16 [5.0v] - Empty
Slot PCI-Express : x1 [5.0v] - Empty
Slot PCI : 32-bit [5.0v] - Empty
>> External Connectors
Serial 16450 Compatible : DB-9 male
Parallel ECP/EPP : DB25 female
Keyboard : PS/2
Mouse : PS/2
Video : DB-15 female
Audio : Mini-jack (headphones)
Network : RJ-45
>> Internal Connectors
PRIMARY IDE : On Board IDE
SECONDARY IDE : On Board IDE
FDD : On Board Floppy
COM1 : 9 Pin Dual Inline (pin 10 cut)
LPT1 : DB25 female
PS/2 Keyboard : PS/2
PS/2 Mouse : PS/2
Line In
Line Out
Mic In
CD In : On Board Sound Input from CD-ROM
Front Panel
SATA1 : On Board IDE
SATA2 : On Board IDE
SATA3 : On Board IDE
SATA4 : On Board IDE
CPU_FAN1
CHA_FAN1
CHA_FAN2
>> System Configuration Options
Option #1 : Unspecified
Option #2 : Unspecified
Option #3 : Unspecified
> Bios : Award BIOS for Intel
>> General Information
Manufacturer : Award BIOS for Intel
Version : GC11010N.86A.0311.2006.0420.1525
Date : 04/20/2006 (mm/dd/yyyy)
Address : 512KB
Copyright : Copyright (C) 2006, Phoenix Technologies, LTD
Motherboard ID : 04/20/2006-RC410-SB450-PTRC-GC-00
SMBios Version : Unspecified
DMI Version : 2.3
>> Characteristics
Flashable : Yes
Socketed : Yes
>> Functionality
APM : Yes
ACPI : Yes
ESCD : No
PnP : Yes
PCI : Yes
ISA : Yes
AGP : Yes
USB : Yes
PCMCIA : No
Smart Battery : No
>> Boot Information
Selectable Boot : Yes
CD-ROM Boot : Yes
PC Card (PCMCIA) Boot : No
I20 Boot : No
LS-120 Boot : Yes
1394 Boot : No
ATAPI ZIP Boot : Yes
Network Boot : No
> Chipset : ATI RC410
>> General Information
NorthBridge : ATI RC410
SouthBridge : SB400 PCI-ISA Bridge
>> NorthBridge Information
Architecture : Northbridge
Manufacturer : ATI (Intel)
Revision : 01
Bus Speed : 133.4MHz
FSB Frequency : 533.5MHz (QDR)
>> Memory Information
Type : DDR-SDRAM PC-3200
Frequency : 200.1MHz
Supported Channels : Dual
ECC Diagnostic : Yes - Disabled
CAS Latency (tCL) : 3 clocks
RAS to CAS (tRCD) : 3 clocks
RAS Precharge (tRP) : 3 clocks
Cycle Time (tRAS) : 6 clocks
>> APIC Information
Version : 2.01
Maximum Interrupts : 24
IRQ Handler enabled : Yes
>> Device Capabilities (PCI)
Latency Timer : 64 clocks
I/O Access : No
Memory Access : Yes
Bus Master Capable : Yes
Special Cycle Recognition : No
Memory Write & Invalidate : No
VGA Palette Snoop : No
Parity Error Response : No
Cycle Wait : No
System Error Line : No
Fast Back-to-Back : No
Detects Parity Errors : No
User Defined Format : No
PCI 66Mhz Bus Support : Yes
New Capability List : No
PCI Support : AGP
> Physical Memory : 1536MB DDR-SDRAM
>> General Information
A0 (RAS 0, RAS 1) : 1024 (Double Bank)
A1 (RAS 2) : 512 (Single Bank)
>> Information SPD EEPROM (A0)
Part Number : Unspecified
Type : DDR-SDRAM PC-2100 (133MHz) - [DDR-266]
Size : 1024MB (2 rows, 4 banks)
Module Buffered : No
Module Registered : No
Module SLi Ready (EPP) : No
Width : 64-bit
Error Correction Capability (ECC) : No
Max. Burst Length : 8
Refresh : Reduced (.5x)7.8 µs, Self Refreshµs
Voltage : SSTL 2.5vv
Prefetch Buffer : 2-bit
Manufacture : 2000
Supported Frequencies : 100MHz, 133MHz
CAS Latency (tCL) : 2 clocks @ 100MHz, 2.5 clocks @ 133MHz
RAS to CAS (tRCD) : 2 clocks @ 100MHz, 3 clocks @ 133MHz
RAS Precharge (tRP) : 2 clocks @ 100MHz, 3 clocks @ 133MHz
Cycle Time (tRAS) : 5 clocks @ 100MHz, 6 clocks @ 133MHz
Type : DDR-SDRAM PC-3200 (200MHz) - [DDR-400]
Size : 512MB (1 rows, 4 banks)
Width : 64-bit
Manufacture : 2000
Supported Frequencies : 200MHz
CAS Latency (tCL) : 3 clocks @ 200MHz
RAS to CAS (tRCD) : 4 clocks @ 200MHz
RAS Precharge (tRP) : 4 clocks @ 200MHz
Cycle Time (tRAS) : 8 clocks @ 200MHz
>> Memory Controller Information
Memory Controller : Standard, EDO
Number of connectors : 2
Max. Module Size : 32MB
Max. Memory Size : 64MB
Supported Speed : 70ns, 60ns
Supported Voltages : 5v
Error Detection Method : No
Error Correction Capability : None
Current/Supported Interleave : 1-way/1-way
> LPC bus : Yes
>> Bus Information
Type : ISA - LPC
Device : SB400 PCI-ISA Bridge
Revision : 80
Number of ISA Connectors : 0
Frequency : 8MHz
Multiplier : 1/4x
DMA Speed : 4MHz
Multiplier : 1/2x
I/O Access : Yes
Memory Access : Yes
Special Cycle Recognition : Yes
Cycle Wait : No
PCI Support : AGP
> PCI Bus : No
> AGP Bus : Yes
>> Bus Information
Number of AGP connectors : 2
>> Bus Information
Device : Radeon XPRESS 200 Series
> USB Bus : Yes
>> Device Information
Device : SB400 USB OHCI Controller
Version : 2.0
Interface : EHCI
Frequency : 60MB/s
>> Device Information
Version : 2.0
Interface : EHCI
Frequency : 60MB/s
>> Device Information
Device : SB400 USB EHCI Controller
Version : 2.0
Interface : EHCI
Frequency : 60MB/s
> SMBus/i2c Bus : Yes
>> General Information
Device : SB400 SMBus Controller
Revision : 82
Frequency : 16 KHz
Address : 0xB00
SBI Protocol Enabled : No
Asus ACPI Access : No
I/O Access : Yes
Memory Access : Yes
Bus Master Capable : No
Cycle Wait : No
PCI Support : AGP
PCI Support : Power Management Interface
PCI Support : PCI Hot-Plug
> Bus HyperTransport : No
> Bus QPI : No
> Bus CardBus : No
> Bus FireWire : No
1.Should i get ddr-400 ram ( i asked the seller for ddr-400 but he gave ddr-226 and after complaining about the problem i exchanged it for ddr-400 but again i got the same ddr-266 ram)?
2.Should i continue with this ddr-266 ram,if i keep this ram(ddr-266) will there be any disadvantage or damage to my computer.
Thank you
