Old 21-12-2011, 07:52 AM   #1 (permalink)
Gamer
Default CRT Monitor Problem
I have been facing a problem with my CRT monitor of 17 inches for the last five days. The problem is-
1. A bright strip of white light divides the monitor in half horizontally.
2. Only the upper portion of the monitor shows the image.
3. The screen is compressed to the upper half of the monitor and very wavy.
Now, today when i switched it on, I found that the monitor is working perfectly. What could be the possible problem?
Gaming Rig:
AMD Phenom II X6 1075T @ 3Ghz | ASUS M5A97 | Sapphire HD6850 1GB | Corsair CX500V2 | G.Skill RipjawsX 4GB @ 1600Mhz | WD Caviar Blue 500GB | ASUS DRW-24B3ST | Dell IN2030M | Logitech MX518 | Cooler Master Elite 311
ArjunKiller is offline   Reply With Quote
Old 21-12-2011, 10:13 AM   #2 (permalink)
Technoholik !!
Tech&ME's Avatar
Default Re: CRT Monitor Problem
You need to take it to a local electronics shop and ask him to RE-Shoulder the PCB.
Basically, shouldering on PCB has dried out.
[Desktop]
[Laptop]
Tech&ME is online now   Reply With Quote
Old 21-12-2011, 04:56 PM   #3 (permalink)
BMG ftw!!
d6bmg's Avatar
He I can't stop myself from informaing you one fact that these re-shoderings won't last much. My oldest CRT 15.6'' monitor died 3 years ago for exactly same reason. At first it started to give the same type of problem described by you, then re-soldered 3 times in next 4 months or so, and then I got pissed & threw it to the store-room.
Buy you ask those mechanics to re-solder it 'with care', and see what happens.
d6bmg is offline   Reply With Quote
Old 21-12-2011, 06:19 PM   #4 (permalink)
Gamer
Thanks anyways, I have ordered Buy Dell 20 Inch WideScreen HD LED Monitor (IN2030M) at Best Price in India - Also find Specifications, Photos, Features & Reviews. I thought this is a GPU problem.
Gaming Rig:
- by kool
