Old 20-12-2011, 07:15 PM   #1 (permalink)
Default How to adjust 15 Amp plug in 5 Amp switch
Hello,
I stay in India and got XBOX 360 few days back.
We have a 5 amp power supply in front of TV.
Check the image:
But the power supply plug is big ... Its a 16Amp plug.. check the img. Also check the power ratings of XBOX.
So how to adjust this 15Amp plug in the 5 Amp plug ..
I tried getting the 15 Amp Spike guard. but again its plug is big as 15amp plug.. Is there any kind of converter?
Kindly let me know the solution .
Regards,
Rahul Kumbhar
rkumbhar is offline   Reply With Quote
Old 20-12-2011, 08:36 PM   #2 (permalink)
aswin1's Avatar
Default Re: How to adjust 15 Amp plug in 5 Amp switch
Cant use this 5amp socket for a 16 amp plug or your circuit will blow.
aswin1 is offline   Reply With Quote
Old 20-12-2011, 09:37 PM   #3 (permalink)
I luv Digit
You cannot plug it into a normal plug. The fuse or MCB will trip.
hotshot05 is offline   Reply With Quote
Old 21-12-2011, 10:27 AM   #4 (permalink)
Technoholik !!
Tech&ME's Avatar
If you want to use this particular Wall Socket to power your xbox then it is not recommended.
What you can do is :
Option 1.: Ask an electrician to change the Socket to 16Amps.
Option 2.: Purchase a extension box of high quality with 16Amps Socket or you can also ask the electrician to make a extension box (wodden) with 16Amps SS Combine Socket and a 16 Amps TOP.
Option 3.: Use some other Wall Socket in your house which has 16Amps Socket.
Note : I will recommend you to go with the first option. Basically in a home (domestic line), all the power is distributed from a single PHASE only, hence, if you change the Socket, you will get the necessary power to run your xbox and the socket will not FRY.
[Desktop]
[Laptop]
Tech&ME is online now   Reply With Quote
- by kool
