Old 20-12-2011, 09:28 AM   #1 (permalink)
Default Games crashing
Pc crashes randomly while playing games.It happened for skyrim and witcher2
My pc is new expect for monitor and hard disk
i5 2500k 3.3ghz
560ti
8gb ram
While playing suddenly monitor says no signal and weird sound comes from speaker and then nothing happens no display, i have to restart PC
i noticed that it only happens when playing on high settings.
sandeep410 is offline   Reply With Quote
Old 20-12-2011, 06:35 PM   #2 (permalink)
Default Re: Games crashing
give details about motherboard & PSU.
run game at mid details and check temperature of both processor & GPU.
btw have you ran any heavy benchmark recently?
Old 20-12-2011, 09:19 PM   #3 (permalink)
Adam young
sukesh1090's Avatar
yup do as sam suggested.first mention your psu and have you used any benchmarking tool that stress your gfx card very badly.reinstall the gfx driver and try to run the game.have you oced your gfx card?
Btw even some background process may cause problem like this.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 20-12-2011, 09:45 PM   #4 (permalink)
Mother board is Asus maximun 4 genez
PSU is corsair 600 GS
While on mid settings Gpu temp was 70 and cpu was 40
Game crashed even on mid settings
I never ran any benchmark
Old 20-12-2011, 10:31 PM   #5 (permalink)
so heat doesn't looks to be a problem. btw pc crashes while playing any other game? it can be driver problem or faulty gpu (even if it ran fine initially) or the motherboard.
Old 20-12-2011, 11:28 PM   #6 (permalink)
It crashes while playing witcher2 and skyrim.It doesnt for saints row and MW3
Havent tested with any other game.
I tried with 2 driver 285 and 275 same problem
Old 20-12-2011, 11:39 PM   #7 (permalink)
Super Moderator
asingh's Avatar
You getting any BSOD dumps..?
asingh is online now   Reply With Quote
Old 21-12-2011, 12:23 PM   #8 (permalink)
No BSOD, Monitor suddenly says No Signal and it goes blank,only way out is restart
Old 21-12-2011, 12:30 PM   #9 (permalink)
Adam young
sukesh1090's Avatar
check events viewer,in that application...... Something like that(sorry i don't remember its exact name and even i am not with my comp so can't check it).there will be some entry which will be in red mark check it and post what is written there.
-Rifleman's Creed
Old 21-12-2011, 04:32 PM   #10 (permalink)
How and where to check that,what is a event viewer
Old 21-12-2011, 05:14 PM   #11 (permalink)
BMG ftw!!
d6bmg's Avatar
Control panel (control) > Adminiatrative tools > event viewer.
d6bmg is offline   Reply With Quote
Old 21-12-2011, 05:38 PM   #12 (permalink)
try removing one stick of ram and try.also try putting ram in any other slot out of ur 4 memory lanes
BLACK STALLION
CORE i7 2600k|MSI P67A-GD65|GSKILL RIPJAWS X CL9 8GB|GTX 580 LIGHTNING|NOCTUA NH-D14|CORSAIR HX 850W|COOLER MASTER HAF X|SEGATE SATA III 1TB+WD GREEN 1TB|BENQ V2210|RAZER DEATH ADDER|
coolgame is offline   Reply With Quote
Old 21-12-2011, 07:27 PM   #13 (permalink)
There are lots of entries in red how to determine which to post
Its a new PC i dont think there will be any problem with ram.
Old 23-12-2011, 02:21 PM   #14 (permalink)
bump... need help
- by kool
