16-12-2011, 06:33 PM
The Warchief
Dvi gpu on vga monitor
Hi !!
My friend has Dell in 1910n. As shown below it has vga connection.
He wanna buy a gpu which has only dvi and hdmi connector.
So what to do now ?
Any kind of converter ?
If yes then any problem with that??
Please help.
16-12-2011, 07:01 PM
Re: Dvi gpu on vga monitor
16-12-2011, 07:21 PM
first of all why do he need to buy Gpu with only Dvi and Hdmi ports..
If he does not know then their are many Graphic cards available with all three ports(vga,Dvi and Hdmi)
If you want Gpu suggestion then pls mention Budget and make and model of PSU
| Athlon II X4 635 @ 2.9Ghz | | Gigabyte GA-MA785GMT-US2H | | Kingston 2x2 Gb 1333Mhz DDR3 | | WDC 500Gb Green | | Palit GTS 250 512mb | | Tagan 500W | | Samsung B2030 | | Lg DVD Writer |
16-12-2011, 07:58 PM
I have DVI-I to VGA converter cable. It works fine.
Just for the note, the four pins on the left you are seeing are the reason why you can get VGA out of DVI-I. These four pins carry analog signals. You can't get VGA out of DVI-D because it lacks these four pins.
16-12-2011, 09:16 PM
The Warchief
^^like below ?
@clmblx actually the local shop we looked at had only those kind of gpu thats why i asked here.
16-12-2011, 09:27 PM
^^ yes...like that.
16-12-2011, 11:52 PM
The Warchief
Ok . . . So there will not be any problem and it is same as vga gpu Right??
Thanks for help... .
17-12-2011, 06:59 AM
Fast 'N' Furious
^^ don't worry too much .. most of the gfx card package comes with a DVI to VGA converter Dongle
look at the thingy on the bottom left corner - just use that
17-12-2011, 07:32 AM
The Warchief
Thank you  .
31-12-2011, 03:27 PM
The Warchief
Ok i got Sapphire HD 6790 . . .for 9000/-
and i got dongle with it , works fine.
31-12-2011, 03:39 PM
iGoogle
9k for HD 6790!! You could have got a HD 6850 in the same price!!
AMD Athlon II X4 630 | MSI 785GM E51 | 4 GB DDR3 1333 Corsair | 500+160 GB Seagate | SAPPHIRE HD 6850 :2subs: | NZXT Gamma | Seasonic 500 Watt :D | Samsung 19" LCD | LG optimus one
01-01-2012, 04:36 AM
Fast 'N' Furious
^^ yep, HD6790 is priced around ~7.9-8.2 at max
@ Kola2842 - congrats on the purchase - so what's model name of the Sapphire HD6790 you got and where from you bought it.
02-01-2012, 02:01 PM
Lol.. Kola got robbed.
HD 6850 is available for 9.2K, dude.
My Sandy Bridge PC :
i3 2100 @ 3.1Ghz, Intel DH61WW, 4GB Corsair DDR3, 2GB EVM(Dynet) DDR3 1333, 500GB Seagate Barracuda 7200.12, Frontech Imagine Case, Hitachi-LG 24X SATA DVD Burner, Corsair CX430 PSU, CM Case Fans.
02-01-2012, 03:27 PM
BMG ftw!!
^^ Now exactly. Price differs from place to place. BTW, congrats on your new purchase!
02-01-2012, 03:40 PM
The Warchief
hmm so i spoiled 1000/-  ok next time i'll explore everywhere.
Also i'm gonna start online shopping.
Its Radeon hd6790 GDDR5. And i got it from Lucknow.
thanks....
 I Accept.
But taking it as (bad) Experience , promise for good next time.
02-01-2012, 05:39 PM
Fullbring
as told by topgear it vga to dvi converter is packaged with card...I also got with my HD5770 so no worries
03-01-2012, 04:17 AM
Fast 'N' Furious
thanks....
 I Accept.
ok ... thanks for the info - from next time just be careful and if you have any doubts about any products price just ask in the forum before making the purchase
