Old 15-12-2011, 09:22 PM   #1 (permalink)
Default ups doesn't give backup while gaming
Hi guys i have an intel i7 920 on an x58 with 4 gb ddr 1333 ram,a zotac gtx 480 a 21" dell monitor.A couple of months ago my ups (luminous 1 kva) would no longer give power backup if i was playing a game , while it would if i wathcing a movie or surfing the net . I have tried another ups microtek 1 kva , but the problem persists. Nowadays when my pc is connected to a 32" led tv even a small fluctuation in voltage causes the pc to restart .Plz help
muditgaur is offline   Reply With Quote
Old 17-12-2011, 08:01 PM   #2 (permalink)
Resistance is Futile.
coolpcguy's Avatar
Default Re: ups doesn't give backup while gaming
You're overloading the UPS
Super User ♦ Moderator | chip/tech2 forum Mod | About me
Gadgets: HP Envy 14 | Google Cr-48 | D-Link DGL 4500 | Denon AH-C360 | Fiio E5 | Galaxy SII GT-I9100 | Dell U2312HM
coolpcguy is offline   Reply With Quote
Old 17-12-2011, 09:05 PM   #3 (permalink)
clmlbx's Avatar
at first It looks like ups must be overloading.. when you game your GPU needs full power and this is what ups could not provide.. but you have 1KVA this must be more then enough for your system..
Pls tell us about your rig so we can calculate your whole power load..
For your current ups.. It looks faulty to me. .
do you have any problem if their is no power failure? while playing games.
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now   Reply With Quote
Old 17-12-2011, 09:48 PM   #4 (permalink)
what psu are you using? some psu have excellent efficiency at low load but raise the load & efficiency goes to hell.
this in turn affects the ups.
- by kool
