Old 12-12-2011, 12:46 AM   #1 (permalink)
Default Hard drive too slow
My hard drive os too slow when on normal mode but it runs ok on safe mode.
But in normal mode its too slow always hangs.What is problem
sandeep410 is offline   Reply With Quote
Old 12-12-2011, 09:16 AM   #2 (permalink)
Default Re: Hard drive too slow
You are most probably virus infected. Scan with an updated anti virus or use this online antivirus HouseCall - Free Online Virus Scan - Trend Micro USA
also make sure your startup is not bloated. Reduce startup programs using Ccleaner. Post a screenshot of task manager if possible.
Old 12-12-2011, 10:52 AM   #3 (permalink)
BMG ftw!!
d6bmg's Avatar
Or, reinstall OS with a good anti-virus & don't fill up your C:\ drive. And also mention the amount of RAM which your PC presently have.
There is no problem with HDD.
d6bmg is offline   Reply With Quote
Old 12-12-2011, 04:09 PM   #4 (permalink)
Its a formated hard drive.Ram is 2GB
Old 13-12-2011, 11:15 AM   #5 (permalink)
Hi sandeep410,
what is the size of your hard drive? What is the size of your OS partition? how many partition you have? all these matters. If you have 320 GB hard drive with 2 partition 160 GB each. It means your OS partition size is 160 GB. so system booting will take time. Reduce the OS partition size.
And if your OS partition is full with data then again your system will get slow.
It means do not fill OS partition full. Also check for bad sectors and viruses.
Sara757 is offline   Reply With Quote
Old 14-12-2011, 01:04 PM   #6 (permalink)
160GB fully formated drive.The drive was too slow so i went ahead with another format,now i cant pass the mother board logo screen 70% of time.I have couple of other 500gb hard disk which i tried and even they cant pass logo screen at all.
Old 14-12-2011, 03:27 PM   #7 (permalink)
BMG ftw!!
d6bmg's Avatar
^^ then the problem isn't with your HDD.
Old 14-12-2011, 04:46 PM   #8 (permalink)
Then wheres problem
Old 14-12-2011, 07:24 PM   #9 (permalink)
unplug all pc parts that don't require pc to start: dvd drive, lan card, gpu, etc & start pc. don't connect HDD. see how far it goes. if it starts ok till "no boot media" msg, try connecting a HDD or try running a live linux cd.
PS: Sorcerer gave me this idea. all credit to him.
Old 14-12-2011, 10:39 PM   #10 (permalink)
It starts faster wehn i remove everything but when i plug 1HDD and DVD drive it gets slower again.I can run linux cd.
Old 22-12-2011, 01:43 PM   #11 (permalink)
Kev.Ved's Avatar
Try defragmenting.
Kev.Ved is offline   Reply With Quote
- by kool
