Old 09-12-2011, 08:18 AM   #1 (permalink)
Default need help- IDE HDD as Ext USB HDD
I have IDE HDD that now I want to use as ext HDD drive.
Pl. suggest which adapters you get and how much costs apprx. I have one SATA<->PATA convertor but it's not so reliable. It causes HDD hang within 15-20 mins.
Is IDE to USB device stable? Does it map all partitions etc justlike int drive.
Thx
patkim is offline   Reply With Quote
Old 09-12-2011, 09:49 AM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: need help- IDE HDD as Ext USB HDD
Thx
u will get an external HDD casing with usb around 600~800.
IDE to USB is stable...& works like normal external drives
Old 10-12-2011, 10:39 PM   #3 (permalink)
prvprv's Avatar
^^ +1
C2D E7200, Gigabyte GA G31M S2L, 2*1 GB Transcend RAM @ 800MHz, 1TB Seagate 7200.12 + 500GB Seagate 7200.12 SATA + 80GB Seagate Barracuda , LG DVD RW @ 22x, BenQ G2220 HD
prvprv is offline   Reply With Quote
Old 12-12-2011, 12:43 PM   #4 (permalink)
Thanks frends. I just checked a few local comp shops. Most do not have any in stock. They are quoting > 900 Rs and again not telling brand etc. They say it's local brand, no warranty but they will give me 1 - 2 months testing warranty.
BTW is it possible to still make it internal drive only? Do we get anything like IDE to USB cable (if any such cable exists!) and USB pin header adoptor for mobo. Then I can make it internal drive only. i.e. use molex power pin from PSU, connect IDE to USB cable and use USB header adopter to connect it to USB pins on mobo.
Old 12-12-2011, 01:21 PM   #5 (permalink)
laborare est orare
Cilus's Avatar
That is completely wrong piece of info and price is too high. The price of SATA to USB external casing is little higher, around 700 bucks for the brands like Frontech, Intex etc.
For PATA to USB casings the price will be around 500 bucks max. Also brands like Intex, Frontech, Techcom provide 1 Yrs of warranty.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now   Reply With Quote
- by kool
