Old 07-12-2011, 11:11 PM   #1 (permalink)
Unhappy My hard disk can make itself vanish
My hard dsik doesnt gets detected 40% of time.when it does gets detected after sometime after logging in it just vanishes.Especially when i am doing something on that hard disk.i ran a smart test and it says ok?
sandeep410 is offline   Reply With Quote
Old 07-12-2011, 11:40 PM   #2 (permalink)
Default Re: My hard disk can make itself vanish
Check if the Hard Disk power connector and SATA connector is properly connected.
My Sandy Bridge PC :
i3 2100 @ 3.1Ghz, Intel DH61WW, 4GB Corsair DDR3, 2GB EVM(Dynet) DDR3 1333, 500GB Seagate Barracuda 7200.12, Frontech Imagine Case, Hitachi-LG 24X SATA DVD Burner, Corsair CX430 PSU, CM Case Fans.
008Rohit is offline   Reply With Quote
Old 08-12-2011, 12:35 AM   #3 (permalink)
clmlbx's Avatar
check sata/pata and power cables.. check if jumper are in proper place.. check for bad sectors..
pls share specs of your rig .
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now   Reply With Quote
Old 08-12-2011, 01:25 AM   #4 (permalink)
if S.M.A.R.T values are ok then it is most likely a power/connector related problem.
whitestar_999 is offline   Reply With Quote
Old 08-12-2011, 04:33 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
Try a different sata port on the mobo - it worked for me once
ToPsPeEeD = FaSt BuT StEaDy
Old 08-12-2011, 02:28 PM   #6 (permalink)
I already tried switching but problem still persits
2 out of 4 hard disk has the problem
Old 08-12-2011, 02:33 PM   #7 (permalink)
avichandana20000's Avatar
if possible use that HDD in another system.
NZXT PHANTOM WHITE|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1TB|LOGITECH G110|APC 650 VA|
avichandana20000 is online now   Reply With Quote
Old 08-12-2011, 04:24 PM   #8 (permalink)
That aint possible any other ideas
Old 08-12-2011, 06:14 PM   #9 (permalink)
is it a pata HDD? check with a new cable. happens usually when cable is badly twisted.
Old 08-12-2011, 09:26 PM   #10 (permalink)
Its a sata,i already said i have switched with 4 cables
Old 08-12-2011, 10:22 PM   #11 (permalink)
clmlbx's Avatar
did you check for Bad sectors as I said earlier ?
Old 08-12-2011, 11:20 PM   #12 (permalink)
scanning disk doesnt show any bad sectors
Old 09-12-2011, 05:30 AM   #13 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ check the SMART status of those HDDs - use HDTune pro or your HDD manufacturers official diagnostic tool for that.
Old 09-12-2011, 09:04 AM   #14 (permalink)
Jai Suresh
lywyre's Avatar
Make sure your hard disk is fixed firmly. Loose cable (power or data) is the most likely cause. Also try a different SATA port on the mother board.
lywyre is offline   Reply With Quote
- by kool
