Old 06-12-2011, 06:26 PM   #1 (permalink)
iGoogle
guru_urug's Avatar
Default Software to make Harddisk data unrecoverable
Im giving off my old internal sata I 160GB to my friend. It has a lot of personal data which I backed up onto my 500GB harddisk. I know that the best way to make data unrecoverable is to repeatedly format and write garbage values and again format in cycles. Please suggest a software that does this. Thanks
AMD Athlon II X4 630 | MSI 785GM E51 | 4 GB DDR3 1333 Corsair | 500+160 GB Seagate | SAPPHIRE HD 6850 :2subs: | NZXT Gamma | Seasonic 500 Watt :D | Samsung 19" LCD | LG optimus one
guru_urug is offline   Reply With Quote
Old 06-12-2011, 09:13 PM   #2 (permalink)
prvprv's Avatar
Default Re: Software to make Harddisk data unrecoverable
Active Kill Disk
You can get it here
Erase hard drive by Active@ KillDisk. Low Level Format.
C2D E7200, Gigabyte GA G31M S2L, 2*1 GB Transcend RAM @ 800MHz, 1TB Seagate 7200.12 + 500GB Seagate 7200.12 SATA + 80GB Seagate Barracuda , LG DVD RW @ 22x, BenQ G2220 HD
prvprv is offline   Reply With Quote
Old 06-12-2011, 09:35 PM   #3 (permalink)
BMG ftw!!
d6bmg's Avatar
There is no way, except for one.
Delete your files & make file blank with same name with zero byte of length. This is the 'only' way to make every deleted file unrecoverable.
d6bmg is offline   Reply With Quote
Old 06-12-2011, 09:46 PM   #4 (permalink)
Electronic.
Neuron's Avatar
Nope.You can use file shredders for this purpose.
File Shredder is a good one.
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 07-12-2011, 06:40 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
take a look at this link
How to REALLY erase a hard drive | ZDNet
ToPsPeEeD = FaSt BuT StEaDy
Old 07-12-2011, 10:29 AM   #6 (permalink)
Fullbring
Zangetsu's Avatar
There are many...but I use TuneUp Shredder....
Eraser is also good & Free
Old 07-12-2011, 12:20 PM   #7 (permalink)
Resistance is Futile.
coolpcguy's Avatar
dban it.
Darik's Boot And Nuke | Hard Drive Disk Wipe and Data Clearing
Super User ♦ Moderator | chip/tech2 forum Mod | About me
Gadgets: HP Envy 14 | Google Cr-48 | D-Link DGL 4500 | Denon AH-C360 | Fiio E5 | Galaxy SII GT-I9100 | Dell U2312HM
coolpcguy is offline   Reply With Quote
Old 08-12-2011, 04:54 PM   #8 (permalink)
iGoogle
guru_urug's Avatar
Thanks Guys for the suggestions.
Will try them
- by kool
