Old 06-12-2011, 11:49 AM   #1 (permalink)
Default Memory card
I have one 2 gb micro sd memory card.it is not showing in win 7.but when we go to computer management->disk management,there it shows as a unallocated space and when i format this card it is not possible to format it .it shows that cyclic redundency error.please help me how to recover this 2 gb memory card.advaced thanks.
subhransu123 is offline   Reply With Quote
Old 06-12-2011, 12:05 PM   #2 (permalink)
BMG ftw!!
d6bmg's Avatar
Default Re: Memory card
Check in that SD card that there is a 'lock' switch. You might have locked your sd card for which your PC can't format it. Unlock it by sliding that lock button to unlock region to format it. Hope this helps.
d6bmg is offline   Reply With Quote
Old 06-12-2011, 07:38 PM   #3 (permalink)
No,i inserted this card through card reader.i tried to format by using hp usb disk storage formatter software but it shows the media is write protected.
Old 06-12-2011, 08:31 PM   #4 (permalink)
Pro/An---tagonist xD
^ Yes and sd cards can be locked via a "lock switch" . See if you have accidentally locked it or not.
Amd athlon II X3 435 unlocked to Phenom II X4 B35 8-) | MSI 785 G-E53 | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz| Seagate 500 gb 7200.12|
Jripper is offline   Reply With Quote
Old 06-12-2011, 09:33 PM   #5 (permalink)
clmlbx's Avatar
here is the lock above all are talking about.
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now   Reply With Quote
Old 06-12-2011, 09:36 PM   #6 (permalink)
ALL I DO IS WIN !!
devx's Avatar
Arrow Re: Memory card
@ subhransu123 >> Check your SD card if it is password protected or not., if yes than remove it., try some other card reader/data card/ and use LINUX to format your card., if your card is of local company than it's totally of no use or if it's branded than replace if it's in warranty period.
devx is offline   Reply With Quote
Old 07-12-2011, 07:16 AM   #7 (permalink)
No it is out of warranty.it is not vissible in linux.it is not above displayed memory card ,it is small,it has no lock key......
Old 07-12-2011, 10:38 AM   #8 (permalink)
clmlbx's Avatar
yes, your card is small but are you using it with it's adaptor (picture in my above post) or you are using it directly in Card reader.
It always refer to Bad storage Device.. Did you try formatting it from disk management.? try other Disk/ partitioning Software's.. also try "chkdsk" command in command prompt for that drive.
Old 07-12-2011, 12:10 PM   #9 (permalink)
i used it with directly card reader.i also used hp usb disk formatter but it shows the media is write protected....it is not seen in commnd prompt....
Old 07-12-2011, 12:45 PM   #10 (permalink)
clmlbx's Avatar
Can you format it from Disk Management. ? does it has Drive letter.. If not Try assigning drive letter to it and then do the following things I said in my earlier post
Old 07-12-2011, 03:32 PM   #11 (permalink)
ALL I DO IS WIN !!
devx's Avatar
@ subransu123 >> Tell me the name of your SD card., check whether your windows PC is virus-free., use Avira's latest free version., it may possible that because of virus your PC is not accepting the card., try it on some other win 7 PC with SD card adapter., check your USB port is enable & working., try some Linux based android phone to detect & format.
If all this doesn't work wait for others to post here or buy new one.
Old 07-12-2011, 03:52 PM   #12 (permalink)
the m0nk who sold his PC!
MatchBoxx's Avatar
Insert it into any Nokia Series 40 phone, and see if the Memory Card is shown as locked (password protected). If it is password protected, then i think a few local "unlockers (hardware solutions)" are available.
Intel i5-2400 || ASUS P8H77-M || G.Skill RipjawsX 8GB (4GBx2) || MSI HD6850 Cyclone PE || Corsair GS600 || Cooler Master Elite 431(Side Panel) || Dell ST2220L || Edifier C2 || APC 1.1 kVA || Seagate GoFlex 1TB
(WBUT semester routine announced. I'm OFF for the time being.)
MatchBoxx is offline   Reply With Quote
- by kool
