Old 06-12-2011, 09:05 AM   #1 (permalink)
Default how to use ide pata 80 gb hdd as external hdd?
I have an old SP0842N samsung 2.5" pata 80 gb hdd, I want to use it as external usb hdd, I googled but didn't get the solution, please help me if there is any possible way to do it.
billamama is offline   Reply With Quote
Old 06-12-2011, 10:03 AM   #2 (permalink)
prvprv's Avatar
Default Re: how to use ide pata 80 gb hdd as external hdd?
Is it a 2.5" or 3.5" drive? When I googled it, it shows 3.5" drive.
you have to buy an "hard disk external casing".
For laptop hard disk (2.5"):
USB Casing for 2.5 inch IDE Laptop Hard Disk | eBay
For desktop hard disk (3.5"):
http://www.ebay.in/itm/3-5-USB-Deskt...ht_3302wt_1140
C2D E7200, Gigabyte GA G31M S2L, 2*1 GB Transcend RAM @ 800MHz, 1TB Seagate 7200.12 + 500GB Seagate 7200.12 SATA + 80GB Seagate Barracuda , LG DVD RW @ 22x, BenQ G2220 HD
prvprv is offline   Reply With Quote
Old 06-12-2011, 12:16 PM   #3 (permalink)
thanks but is it (desktop hard disk) compatible with win-7?
Old 06-12-2011, 12:50 PM   #4 (permalink)
yes it is.
Old 06-12-2011, 07:24 PM   #5 (permalink)
thanks but today when I was checking my hdd (80gb pata) connecting with ide cable, my pc didn't recognize it and the hdd was producing a constant tic tac sound, what I did't get at all! is it ok for old hdd to produce such sound?
Old 06-12-2011, 08:12 PM   #6 (permalink)
check with some HDD testing tool if theres any bad sector or it can be the spindle motor not able to spin the platters properly at constant speed.
Old 06-12-2011, 10:38 PM   #7 (permalink)
Electronic.
Neuron's Avatar
That sound isn't normal.Try connecting it to some other computer with another IDE cable if possible.
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 07-12-2011, 06:48 AM   #8 (permalink)
I tried but it is not detected and kept making the strange tic tac noise
Old 07-12-2011, 06:48 AM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
the HDD platter(s) inside is not spinning properly and that's why you are hearing tic tac sound - if it's still under warranty send it for RMA. This happens when a HDD is not used for a long time and is not stored properly - also check the IDE cable your are using and the mobo IDE slot too.
But if it's out of warranty you can try this ( do these at your own risk ) - shake the HDD 50-60 times and gently slap on the shiny surface and on the sides and see if the mobo recognizes it or not.
ToPsPeEeD = FaSt BuT StEaDy
- by kool
