Old 06-12-2011, 03:19 AM   #1 (permalink)
Post Computer Starts with a black screen??
Hello, Friends
I m facing a problem in my PC for recent few days-
When I Start my PC then there is no sign of the loading of BIOS or Windows.
After 15 to 20 minutes then the computer starts (display comes).
What is the problem with my PC, can any one please help me???
ravi23071988 is offline   Reply With Quote
Old 06-12-2011, 01:01 PM   #2 (permalink)
Default Re: Computer Starts with a black screen??
refit the RAM, check the processor heat sink. Reset the CMOS battery. Reconnect HDD wires properly. Check the PSU.
Old 06-12-2011, 01:13 PM   #3 (permalink)
Originally Posted by ravi23071988 View Post
Hello, Friends
can you elaborate what happens exactly in a step by step manner?
Old 07-12-2011, 07:19 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
Humidity sometime can cause this - put some silica gel packs inside of your cabby or if you have Ac in the room turn it off, open the doors and after an hour or so start the comp.
Check HDD and ODD and the cables and ports on the mobo - if you have any USB device attached to the comp remove it it and try starting the comp.
BTW, tell us what GFX card, mobo, cpu and PSu you are using.
Mention manufacturer and model names of those and mobo bios version.
ToPsPeEeD = FaSt BuT StEaDy
Old 07-12-2011, 01:10 PM   #5 (permalink)
Take the RAM out. Clean the bottom part of it with a cloth, fit it in a different slot.
My Sandy Bridge PC :
i3 2100 @ 3.1Ghz, Intel DH61WW, 4GB Corsair DDR3, 2GB EVM(Dynet) DDR3 1333, 500GB Seagate Barracuda 7200.12, Frontech Imagine Case, Hitachi-LG 24X SATA DVD Burner, Corsair CX430 PSU, CM Case Fans.
008Rohit is offline   Reply With Quote
- by kool
