which are the cheapest gamepads available in the market for games like BF3 or MW3?? i even play games like NFS series which would be a suitable pad for me the cheaper the better it would be guys
If you want there are gamepads from lots of local brands such as enter, zebronics etc. available in the market costing Rs200-300. If you want to go for something branded, gamepads from logitech start from Rs600. If you're willing to spend then do get the XBOX 360 gamepad as suggested by Tenida. Its vibration feedback, build and layout make it much better than the others.
Nothing is true. Everything is permitted.
Trust Me Get The XBOX one For RS 1116... I Just ordered It after Trying Many Local One ....Almost 5 of them...even the Logitech one...Logitech One is still working fine but local one just dies in month or two....
Intel Core i5 2500k ||MSI Z68 GD65 B3||Corsair A70:doublethumb:||Gskills Ripjaws X 4GB||Corsair GS 700 :clap2:||Segate Baracuda 1TB X 2 :shock:||Zotac Gforce 9600 GT 1GB HD 7870 Coming Soon ||Coolermaster ELITE 430 :P ||DELL IN 2020||Logitech G 300 :doublethumb:||Logitech Media Combo 200||Creative SBS A335||Tt eSport Shock Gaming Headset White || Xbox 360 Controller
@OP-Ayuclack is absulately correct.....buy the xbox controller its best out there at cheap price other local ones are just crap....don't buy them....if u r out of budget ...then save some money and buy later.
Buy Xbox 360 controller if you can .. Best to buy that it works in all Games as it is supported by most games if not all.. and it is pre-configured.. while local one will have to go with trial and error method.. Buy Frontech if you wish to go for local as this is best in all(locals)
