Old 03-12-2011, 08:11 PM   #1 (permalink)
Default [Solved]M.B Broken Component
Sry 4 confusing title , i dont know the Exact Name of the part
MotherbOad Link : Foxconn - Products: Motherboard
Socket : Socket 754 for AMD Athlon™ 64 / Sempron™ processors
Q 1)Is it possible to get Replacement Item (marked in Picture)- Due to it broken Unable to secure Heat sink properly
Q2) What is the exact Name of that part ?
some1 forcefully tried to pull heatsink out and got broken (friends pc) , i chked system now , its working proper other than Heat sink securing problem
AMD Phenom II X6 1055T ,Benq G2220HD 22 ,GIGABYTE GA-880GM-UD2H ,COOLER MASTER Elite 310 ,CORSAIR 2GB 240-Pin DDR3 X3[6GB] , FSP Saga II 500 W HD 5750 . Hyper 212+ OS :Win 7 64 bit
Rajesh345 is offline
Old 05-12-2011, 06:49 AM   #2 (permalink)
Default Re: M.B Broken Component
bumb after 2 days , Any1 know from any online shop;s from where i can get that broken piece
Old 05-12-2011, 11:13 AM   #3 (permalink)
clmlbx's Avatar
don't look online for it. Instead search for local hardware repair man..But pls make sure of his charges before giving him to repair.. If charges are high you can look for second hand MB(if available.) in local market.
But IMO better repair instead for going for second hand MB as You MB has jut one problem but one you buy .. ? no one knows how many..maybe later it will cost you more.. second hand electronics products are very risky in nature.
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now
Old 05-12-2011, 11:41 AM   #4 (permalink)
Thank you i will try to do that , but do u know the name of that piece ?
atm i kept the case vertically temp is ~ 40-45 deg at load
Old 05-12-2011, 12:48 PM   #5 (permalink)
clmlbx's Avatar
^^ you mean horizontally .. right? I have not seen that type of mb's and picture is very low res and blurry so don't know exactly what is broken. But as you say it can't hold heat sink so best you can say is heat sink holder.. Best way to get is if some one has old scratch(un-repairable old) motherboard then it can be replaced from that MB....If you can find that then I guess you can do it your self.. because IMO nothing soldering or repairing thing is required .
this is your MB
Old 05-12-2011, 04:05 PM   #6 (permalink)
AMD CPU Retention Retainer Bracket Holder
Sam is online now
Old 05-12-2011, 06:17 PM   #7 (permalink)
clmlbx's Avatar
^^ If he try to search local market with that name then He will get blank,weird faces.. and he will be
Old 05-12-2011, 06:31 PM   #8 (permalink)
Thank u both.
its for me for knowing the name
Thread can b closed now
Old 05-12-2011, 09:42 PM   #9 (permalink)
^^ search in ebay. i found a seller there.
sad but true.
closing thread. if you want to reopen thread, simply PM me or any other mod
Sam is online now
- by kool
