Hello people!
After reading a thread about dual display setup I had a feeling about trying it myself so I attached monitor from my old PC with current PC.
Both displays are working fine, I can drag and drop the windows I want to other screen BUT when I tried to run Burnout Paradise on dual screen, it didn't use the second monitor. I enabled multi display in settings too, but images that are to be displayed on secondary monitor is also being displayed on my main monitor..
I googled about this and found that I am not the only one having these issues, but I was also not able to find any solution. No game is able to use the second monitor. Another thing I noted that the task bar is only on main monitor and doesn't extends till main display.
How can I possibly make games run on dual monitor?
PS: I know that it may be difficult for a 6850 to handle games at dual screens, but I just
want to try
PPS: Both monitors have different resolution, but I dont think this can be the reason. Can it be?
