Old 29-11-2011, 06:14 PM   #1 (permalink)
ratzee199's Avatar
Default Running out of Disk Space
Hi,
I am facing a problem with my C: for last few weeks.
I have a desktop PC with dual booting option-Windows 7 and Windows XP. My Windows XP is in C: and Windows 7 installed in D:.
For the last few weeks almost every now and then I am getting an error message such as -C: is out of memory. in C: I have allocated 20GB of space. I do use CCleaner very often to free up the recycle bins, temporary files etc. I have removed some 2 GB of programs from C:. Still after each time I freed up the programs the C: is getting full. I am not able to figure it out why.
I am using the licensed version of Kaspersky 2011 Antivirus and I install all the programs in F: or in external hard disks. I rarely installed programs in C:. Is it a virus problem or Malware?...Please help. I want to get rid of this problem as well as with Windows XP also.
Jay
ratzee199 is offline   Reply With Quote
Old 29-11-2011, 07:29 PM   #2 (permalink)
iGoogle
guru_urug's Avatar
Default Re: Running out of Disk Space
shift your swap space to another partition..whenever your system runs out of ram it starts using the swap space on hidden.
AMD Athlon II X4 630 | MSI 785GM E51 | 4 GB DDR3 1333 Corsair | 500+160 GB Seagate | SAPPHIRE HD 6850 :2subs: | NZXT Gamma | Seasonic 500 Watt :D | Samsung 19" LCD | LG optimus one
guru_urug is offline   Reply With Quote
Old 29-11-2011, 08:06 PM   #3 (permalink)
Dust in the Wind
Skud's Avatar
Also turn off System Restore or allocate lesser space for it.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 29-11-2011, 08:21 PM   #4 (permalink)
boot into XP.go to my computer-->tools-->folder options-->view tab.select"show hidden files & folders" & uncheck "hide protected operating system files(recommended)"option.you will now see files & folders which were not visible before in C drive.if you have enabled hibernation a single hiberfil.sys file equal to RAM size will be there.also there will be folders like system volume info & $recycle.bin.check their sizes & take appropriate steps if you find them too large in size as suggested in above posts.
whitestar_999 is offline   Reply With Quote
Old 30-11-2011, 02:32 AM   #5 (permalink)
I applied your suggestions for my laptop running on Windows 7 and found a hiberfil.sys amounting to 2.80GB. Is it safe to delete this hiberfil.sys file.
Also, should Hibernate consequently be turned off?
Thank you.
let us all see the "i" in the "u".
insaneYLN is offline   Reply With Quote
Old 30-11-2011, 10:44 AM   #6 (permalink)
mithun_mrg's Avatar
hyberfil.sys file that windows uses to write the memory on the hard drive for hibernation u need to turn hibernation off to delete the file
To delete the file
Click Start>allPrograms>accessories
Rightclick>Command Prompt
Select Run as administrator
Grant permisssion to change system settings
In thecommand prompt window type "powercfg -h off" enter
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 30-11-2011, 11:52 PM   #7 (permalink)
I am a bit perplexed. Theoretically, the hibernate mode creates a file of a capacity which is equivalent to the amount of RAM.
My laptop has 4GB RAM of which 3.74GB is usable (the remainder, I reckon is used by the ATI Radeon Mobility graphics), yet the hiberfil.sys file size is 2.80GB
May I know why it is so?
Thank you.
Old 01-12-2011, 07:14 AM   #8 (permalink)
mithun_mrg's Avatar
^^ The total size depends upon the amount of active ram on the system not the total ram it writes the whole ram image on the hiberfil.sys file
Old 01-12-2011, 10:32 AM   #9 (permalink)
Fullbring
Zangetsu's Avatar
@ratzee199: Disable System Restore option in both C & D.also delete the existing restore points using CCleaner.
use tune up utilities 2011 tool "Disk Space explorer which will give enuf details about files & folders which are huge in size.
- by kool
