Re: 4gb ram suggestions
Originally Posted by d6bmg
For optimal performance, buy another XMS3 4GB Stick, not (2X2GB) sticks.
That's what he was planning to get, anyway.
@ OP
If you want the modules to run in dual-channel mode you'll have to get another XMS module. However, for example, if your XMS has these specs :
DDR 1333Mhz
CAS Latency : 9-9-9-24
and you buy another stick with the same specs (Such as Gskill Value Series), chances are there that then too they'll work in dual channel mode, but thats just hit or miss. So, I guess the best bet will be another XMS3 if you dont want to risk dual channel operation.
My Sandy Bridge PC :
i3 2100 @ 3.1Ghz, Intel DH61WW, 4GB Corsair DDR3, 2GB EVM(Dynet) DDR3 1333, 500GB Seagate Barracuda 7200.12, Frontech Imagine Case, Hitachi-LG 24X SATA DVD Burner, Corsair CX430 PSU, CM Case Fans.
