Old 26-11-2011, 04:09 PM   #1 (permalink)
Neophyte
Default Help Buying new RAM
Hi, Guys I want to buy a new set of ram maybe 8GB(4GB each), as by looking at my config u see i have 2GB Kingstone DDR3 and i want to go for CORSAIR or GSKILL. I looked for CORSAIR Vengeance but i think it doesnt support amd processors, i dont know i looked in Corsair website, it says the Corsair DOMINATOR supports but its way to expensive for my budget. My budget is 4k.
Also, I want it as i work mostly in After Effects,so i want to have longer ram preview and good performance.
So, please HELP
Motherboard: MSI E53
Processor : Amd Phenom X620
Graphics : Palit GTS 260 896mb Express Card
Hard Drive : 500GB Western Digital
Smps : Gigabyte 460 watt
Ram : 2GB Kingstone DDR3
manab_bikash is offline   Reply With Quote
Old 26-11-2011, 06:02 PM   #2 (permalink)
BMG ftw!!
d6bmg's Avatar
Default Re: Help Buying new RAM
Gskill F3-12800CL9D-8GBXL @3.2K
d6bmg is offline   Reply With Quote
Old 26-11-2011, 06:37 PM   #3 (permalink)
Neophyte
Gskill F3-12800CL9D-8GBXL will this support my config...
Old 26-11-2011, 08:18 PM   #4 (permalink)
BMG ftw!!
d6bmg's Avatar
Yes, it will support your config, but it will run @1333MHz.
You will get 1600MHz only while overclocking.
Old 27-11-2011, 11:08 AM   #5 (permalink)
Neophyte
ok, i have no idea how to overclock....
can you plz help how can i overclock in this config.. & also will it support with my installed ram, if i get the 3 together
also can i get any corsair ram within 4k for my config in case...
Old 27-11-2011, 02:44 PM   #6 (permalink)
BMG ftw!!
d6bmg's Avatar
You will get much cheaper Corsair RAM: Corsair Value 4GB 1333 MHz CL9 DDR3 @ 1.2K
Buy two of them, and you will get them @2.4K, saving your 1.6K.
It would be more than enough for your current config.
Old 27-11-2011, 02:51 PM   #7 (permalink)
Neophyte
Which 1s performance is better Corsair or Gskill..??
Old 27-11-2011, 08:26 PM   #8 (permalink)
BMG ftw!!
d6bmg's Avatar
Corsair is better value for money.
Old 27-11-2011, 08:35 PM   #9 (permalink)
How much warranty do corsair value select rams have, ddr3
Visit http://gfxpixels.co.nr for free custom graphics!!
aquafusion is offline   Reply With Quote
Old 28-11-2011, 06:59 AM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ all ram memory modules have a lifetime warranty
ToPsPeEeD = FaSt BuT StEaDy
Old 28-11-2011, 11:42 AM   #11 (permalink)
Neophyte
I visited a website Crucial.com and scan for my board and found my memory type to be Memory Type : DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-16000, DDR3 PC3-14900
Guys i just wanted to know, if i go for Corsair Dominator or Vengeance which 1 will support my system...and what will be the price..
Actually, if i get the RAM i dont want 2 change it for at least 3 yrs, so i want 2 get the good 1 with a heat sink. I think you got the idea...
Please HELP..
Dominator® with DHX Pro Connector — 8GB Dual Channel DDR3 Memory Kit (CMP8GX3M2A1600C9)
OR
XMS3 — 8GB Dual Channel DDR3 Memory Kit (CMX8GX3M2A1600C9)
OR
[ Ripjaws ] F3-12800CL9S-2GBRL (2Gx1) / F3-12800CL9D-4GBRL (2Gx2) / F3-12800CL9Q-8GBRL (2Gx4)
If i get this RAM will it support my system and what is its price..
Old 28-11-2011, 08:19 PM   #12 (permalink)
BMG ftw!!
d6bmg's Avatar
I guess it's comes down to 10 years in India, right?
OR
OR
Dominator is a waste for your rig. You don't need it.
XMS3 modules are good, but a priced a bit higher than equivalent ripjawsX.
As for ripjawsX, 1st one if of 2GB and you wanted 4GB min in your first post. 2nd one is good, and you can't use 3rd one unless you don't want to use the existing RAM, as you already have one 2 GB module. So, only 3 slots are open.
Old 28-11-2011, 09:46 PM   #13 (permalink)
laborare est orare
Cilus's Avatar
manab_bikash, overclocking the Ram to run at 1600 MHz speed in your motherboard is easy; just check the Motherboard's manual book. 1st you have to go the BIOS of the motherboard and there will be a section for overclocking. Go into that. You will find one entry: CPU: DRam ratio which is set to AUTO. Change it to MANUAL and there will be four option available. Select the 1:4 value, save the BIOS and you are done. It is clearly written step by step in your motherboard's manual with each of the BIOS screens, Screenshots and explanation about the options. If you've lots it, download the PDF file from the product's page in MSI site.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now   Reply With Quote
Old 29-11-2011, 05:24 AM   #14 (permalink)
Fast 'N' Furious
topgear's Avatar
yep, in here it's 10 year but that's some long warranty they offer enough to be called Life Time
Old 29-11-2011, 05:35 PM   #15 (permalink)
Neophyte
As u said earlier...
I think i will go for this 1 its price in Corsair website is $59.99 i.e 3119 approx.
Is it ok if i go with this 1...Please Suggest...
Old 30-11-2011, 05:17 AM   #16 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ the price is all right and you can get those
Old 30-11-2011, 11:00 AM   #17 (permalink)
Neophyte
This Ram is not available in here...they are suggesting me to go with Gskill Sniper DDR3-1600..
Old 30-11-2011, 02:26 PM   #18 (permalink)
bajaj151's Avatar
I also need suggestion :
Motherboard : MSI 890GXM G65
Processor : Phenom II x6 1055T
Currently, I have Gskill Ripjaws DDR3 (Blue) CL7 (2*2GB).
But I can't able to find this RAM in market.
So,planning for same (2*4GB) DDR3 rams.
1) Corsair XMS3 1600mhz
2) G skill Sniper 1600mhz
3) Corsair Vengeance 1600mhz
(I will also use Hyper 212 EVO)
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now   Reply With Quote
Old 02-12-2011, 01:58 PM   #19 (permalink)
Manchester United
abhijit_reddevil's Avatar
Hello,
I also need suggestion. Following is my current config:
AMD Phenom II X4 955
Gigabyte 890GPA-UD3H
Corsair XMS3 1333Mhz 4GB
Sapphire Radeon HD 6870 Twin Frozer Edition
I want to buy another 4GB stick, and I want to stick to Corsair XMS3. Many of the sticks I see online have 1600Mhz specified as their frequency. Should those work at 1333Mhz because my existing stick is at 1333Mhz?
For example, will this work?
Flipkart: Corsair 4 GB DDR3: Ram
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline   Reply With Quote
Old 02-12-2011, 07:01 PM   #20 (permalink)
BMG ftw!!
d6bmg's Avatar
All are almost same. Buy any of them. G Skill RipjawsX is also very good.
P.S. try making separate thread instead of posting in other's thread.
Yes, you are right. Using 1600MHz RAM with another 1333MHz RAM is of no use. As the 1600MHz ram would work @1333MHz. I would suggest you to buy Corsair value RAM Link and save your money. As buying 1600MHz RAM is nothing but waste of extra money that you are paying for the extra speed which you can't use.
- by kool
