Old 25-11-2011, 02:02 PM   #1 (permalink)
Manchester United
abhijit_reddevil's Avatar
Default Questions about Gigabyte motherboard
Hello,
I have Gigabyte motherboard 890GPA-UD3H. Couple of questions:
1) Which is the USB 3.0 port on the motherboard?
2) How do I use it's On-off charge feature?
Thanks.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline   Reply With Quote
Old 25-11-2011, 02:16 PM   #2 (permalink)
The Sorcerer's Avatar
Default Re: Questions about Gigabyte motherboard
1. The blue coloured ports on the rear.
2. You will see One of the USB 2.0 headers marked RED. I think you just use that and connect it, maybe some software is bundled with it or maybe some bios feature but that's turned on by default unless you turned it off. You simply connect it. That's about it.
Hardware BBQ
The Sorcerer is online now   Reply With Quote
Old 25-11-2011, 03:01 PM   #3 (permalink)
Manchester United
Thanks.
There is a software called on-off charge to be downloaded from the gigabyte website. I will try it out.
- by kool
