Old 24-11-2011, 11:43 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Memory by Platform??
On Corsair site I find separation of memory modules by platform like Intel / AMD. Is there any such categorization done ?
I plan to upgrade my system to AMD based and shall use 2 DDR3 mem modules of same size & make for enabling dual channel. Is there any other thing to be considered here? Thx
patkim is offline   Reply With Quote
Old 24-11-2011, 01:15 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Memory by Platform??
AFAIK the Corsair memory modules will work on any platform AMD or Intel...
Old 25-11-2011, 05:01 AM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
@ patkim - just tell us which mobo (make and model ) and cpu (make and model ) you will be using.
ToPsPeEeD = FaSt BuT StEaDy
Old 25-11-2011, 11:10 AM   #4 (permalink)
The Sorcerer's Avatar
Originally Posted by Zangetsu View Post
AFAIK Most of/almost all- largely depending on the rev version of the memory stick/motherboard/Bios Ver. the Corsair memory modules will work on any platform AMD or Intel...
Fixed- only because there have been actual cases. They DO matter.
Honestly I hope the memory scene doesn't become SO complicated that newer memory kits would refuse to boot boards with initial chipset's rev versions. That's seriously going to suck big time.
Hardware BBQ
The Sorcerer is online now   Reply With Quote
Old 25-11-2011, 01:59 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Awwh..man. That will be bad, if DIMMs have to be purchased looking at the chipset first.
asingh is online now   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/149157-memory-platform.html
Memory by Platform?? This thread Refback 27-03-2012 08:47 PM
- by kool
