Old 22-11-2011, 08:09 PM   #1 (permalink)
dharmil007's Avatar
Default WiFi Problem - not connecting
My whole college Campus is enabled with WiFi facility.
But the officials said that u cannot connect it through mobile.
U can only connect it via laptop.
i tried connecting it via mobile, but it asked many other things other then id & password,
i Have the id & password, but i dont know what to write in other things.
Can anyone help me please.
i m attaching a ScreenShot of the things asked while connecting to WiFi
PHENOM II X6 @ 2.8GHz || GA-880GM-UD2H || Kingston 2x2GB Dual-Channel DDR3 || 500GB WDC || Logitech MX518 || Samsung 20" LED SA20A300N
dharmil007 is offline   Reply With Quote
Old 23-11-2011, 03:20 AM   #2 (permalink)
Default Re: WiFi Problem - not connecting
I assume you also feed the username and password in you lappy....
Then put the same details:
username = identity
anonymous identity = (keep it blank)
Password = same password
Desktop: Intel i5 2500k | CM 212 Evo | EVGA GTX 570 | Gigabyte Z68X-UD3H-B3 | 8 GB corsair vengeance DDR3| Corsair TX650V2 | Asus Xonar D2/PM | 160+250+500 GB | Viewsonic VX2260wm | Creative Inspire 5200 5.1 | Dolby + DTS | Win 7x64 Pro
Laptop: HP HDX 1255EE - Intel P8600 | Nvidia 130mGT 1GB | 4GB DDR2 | 320GB | BDROM-DVDRAM | HP 16" HD Infinity Display 1080p | Dolby Home Theater | Win 7x64 Pro
TabletPC: HP TM2 1050EF - Intel SU7300 | ATI 4550m + Intel 4500MHD | 4GB DDR3 | 120GB SSD | Dolby Advanced Audio | Win 8x64 DP
vicedens2002 is offline   Reply With Quote
Old 23-11-2011, 07:59 AM   #3 (permalink)
mithun_mrg's Avatar
i doubt he will be able to connect like that u college is using Extensible Authentication Protocol exactly PEAP=Protected Extensible Authentication Protocol
try importing the credential certificate from any pc to the phone through the method mentioned here
How to install EAP TLS certificates for WiFi - Android Security Discussions | Google Groups
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 23-11-2011, 08:05 AM   #4 (permalink)
Actually I have done like this in 2 collages.... My collage also uses PEAP... set “Phase 2 authentication” to “MSCHAPV2” and
username = identity
- by kool
