Old 19-11-2011, 08:28 PM   #1 (permalink)
rjt
Red face suggest memory settings
Dynet DNHMAU2GC8FER-A7 2gb PC2 - 6400u - 555; Max : 800 MHz.
Suggest the memory settings latency etc. for the above RAM in BIOS.
rjt is offline   Reply With Quote
Old 19-11-2011, 10:38 PM   #2 (permalink)
Mmmph!!!
doomgiver's Avatar
Default Re: suggest memory settings
that module is of a budget/low price manufacturer.
i doubt you will get much performance out of it
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
doomgiver is offline   Reply With Quote
- by kool
