Old 15-11-2011, 12:29 AM   #1 (permalink)
Default HDMI query
I somehow find HDMI a bit confusing!!
I am planning to upgrade to new system n shortlisted a few Mobos having HDMI out. e,g, Gigabyte 880G based mobos.
My query is that once I hook up my LCD TV as monitor with HDMI port on mobo, what happens to the audio out from the PC. Does the ananlog audio out gets disabled and I shall hear sound thru the TV?
Is it possible to use HDMI only for video display and continue to use the exisiting multimedia speakers connected to the sound card output?
patkim is offline   Reply With Quote
Old 15-11-2011, 11:28 AM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: HDMI query
if u r HDMI and audio port both are on the same mobo, then you can get sound in both.
analog audio out doesn't get disabled.
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 15-11-2011, 12:02 PM   #3 (permalink)
yes, completely possible. Have a look at this screenshot:
This AMD HDMI port is on my graphic card.
Old 15-11-2011, 12:09 PM   #4 (permalink)
Fullbring
Zangetsu's Avatar
the screen posted by ico above is informative...
the analog audio doesn't get disabled..
yes...I use both HDMI (for video) & analog audio..
Old 15-11-2011, 08:54 PM   #5 (permalink)
Never give up!!
jerrin_ss5's Avatar
Thanks for the info. Zangetsu didn't it could work like that !!
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 20-11-2011, 09:38 PM   #6 (permalink)
gr8..thanks all for the info.
Old 21-11-2011, 09:47 PM   #7 (permalink)
If you totally don't use the HDMI audio. Try to disable it, so that softwares won't get confused on seeing different output devices.
Desktop: Intel i5 2500k | CM 212 Evo | EVGA GTX 570 | Gigabyte Z68X-UD3H-B3 | 8 GB corsair vengeance DDR3| Corsair TX650V2 | Asus Xonar D2/PM | 160+250+500 GB | Viewsonic VX2260wm | Creative Inspire 5200 5.1 | Dolby + DTS | Win 7x64 Pro
Laptop: HP HDX 1255EE - Intel P8600 | Nvidia 130mGT 1GB | 4GB DDR2 | 320GB | BDROM-DVDRAM | HP 16" HD Infinity Display 1080p | Dolby Home Theater | Win 7x64 Pro
TabletPC: HP TM2 1050EF - Intel SU7300 | ATI 4550m + Intel 4500MHD | 4GB DDR3 | 120GB SSD | Dolby Advanced Audio | Win 8x64 DP
vicedens2002 is offline   Reply With Quote
Old 21-11-2011, 11:51 PM   #8 (permalink)
BMG ftw!!
d6bmg's Avatar
^^ dude, I think ico have already solved the problem of OP.
d6bmg is offline   Reply With Quote
Old 22-11-2011, 03:05 PM   #9 (permalink)
Cool Buddy's Avatar
When I hooked up my TV to my graphics card via HDMI, I could use only one output, either the one on the mobo or through graphics card in the TV. I couldn't use both simultaneously although I could choose which one I wanted to use.
So in a way, the analog port does get disabled when HDMI is connected, although it is possible to enable it.
Nokia 5230 :(
Canon IXUS 115 HS :)
- by kool
