Old 12-11-2011, 11:36 PM   #1 (permalink)
Default CD In / Aux connector
I used to connect a cable from back panel of CD/DVD drive to the CD In/aux 4 pin connector on the mobo with onboard sound.
I guess the CD rippers would read the data thru this connector.
newer mobos do not have this 4 pin CD in/aux connector. Will CD ripping still be possible without use of such connectors?
patkim is offline   Reply With Quote
Old 13-11-2011, 04:10 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: CD In / Aux connector
CD ripping apps should work just fine as before
ToPsPeEeD = FaSt BuT StEaDy
Old 13-11-2011, 11:22 AM   #3 (permalink)
In earlier times, processors were much less powerful than they are now and it was desireable to relieve them of some of their workload wherever possible. One such work is decoding the raw digital audio data from optical discs. CD/DVD drives have built-in decoders and their output is taken from the 4-pin audio connector. Using that relieves the main processor from some of its workload.
Modern computers are so powerful that audio processing takes up only a small part of its processing power. Using or not using the optical drive's built-in processor hardly makes any difference now.
pimpom is offline   Reply With Quote
Old 13-11-2011, 08:31 PM   #4 (permalink)
BMG ftw!!
d6bmg's Avatar
Firstly, you have got a 4pin CD in/aux connector, congrats!! They are rare nowadays. See the post of pimpom. He have already explained it already.
d6bmg is offline   Reply With Quote
- by kool
