Old 12-11-2011, 11:16 PM   #1 (permalink)
ajayritik's Avatar
Default Need help setting up internal HDD in external HDD box
I have bought an external HDD enclosure so that I can use my old IDE HDD as external HDD. However when I connected everything I don't find the HDD being detected. Can someone please help me on this.
Also in the manual it's mentioned that the HDD Should be set up as Master. Do I do this using the jumper?
ajayritik is online now   Reply With Quote
Old 12-11-2011, 11:23 PM   #2 (permalink)
Default Re: Need help setting up internal HDD in external HDD box
is the casing receiving power? have you connected the power cable or whatever came with the casing to the hard drive?
yup. use jumper. instructions are given in a white sticker on the HDD itself.
Old 12-11-2011, 11:38 PM   #3 (permalink)
ajayritik's Avatar
I don't have a spare jumper. Need to find one.
Old 13-11-2011, 08:45 PM   #4 (permalink)
BMG ftw!!
d6bmg's Avatar
It should be provided with that case.
d6bmg is offline   Reply With Quote
Old 14-11-2011, 10:54 AM   #5 (permalink)
ajayritik's Avatar
I have connected the power and rechecked it as well
There is no jumper that was provided with it.
Now my dilemna is whether there is a problem with the box or my HDD itself. How do I troubleshoot?
Anybody here who has used internal HDD's in External HDD box.
Old 14-11-2011, 11:03 AM   #6 (permalink)
mithun_mrg's Avatar
first verify that the hdd is working connect is directly to the pc & see u can get the jumper from any computer shop for testing use the one in the cd/dvd drive try these & get back
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 14-11-2011, 11:36 AM   #7 (permalink)
Fullbring
Zangetsu's Avatar
y u need a jumper for just making an External HDD (from internal one) detectable...
I didn't use any jumper while doing the same...jumper is only used when u are
connecting the IDE drives (multiple) to make a master-slave setup...
but in current scenario u are using the USB connector for the external casing...so it will work as external HDD...
Old 14-11-2011, 11:41 AM   #8 (permalink)
ajayritik's Avatar
Zangetsu as I mentioned in my post. It says that I need to setup the HDD as Master. I really don't remember how to do this master/slave thing. I remember earlier few years back when I used to connect a jumper for this setting.
Old 14-11-2011, 11:43 AM   #9 (permalink)
mithun_mrg's Avatar
post a pic of the top of the HDD sticker or refer it instructions r given there clearly
Old 14-11-2011, 11:51 AM   #10 (permalink)
Fullbring
Zangetsu's Avatar
all the jumper settings for master/slave are common for HDD.
just read the sticker attached to the HDD...
but AFAIK for external connection master/slave is not needed...
bcoz even if u do make it a master then from which master the system will boot.. internal HDD (master) or the external HDD (master)
Old 14-11-2011, 12:02 PM   #11 (permalink)
ajayritik's Avatar
Even I thought the same. I thought it will not matter whether it's master or slave for external hdd.
Because this product doesn't look like branded to me I'm getting worried. Hope I didn't screw up my money.
Old 14-11-2011, 09:22 PM   #12 (permalink)
BMG ftw!!
d6bmg's Avatar
Master or slave connection specification is need only for internal drives. As you are using it via USB, master or slave drive makes no sense at all. Actually, you won't get any such configuration while installing HDD.
Old 15-11-2011, 09:53 AM   #13 (permalink)
Fullbring
Zangetsu's Avatar
whats the product name?
thats what I said in post#7 above
Old 17-11-2011, 12:10 PM   #14 (permalink)
ajayritik's Avatar
There is no product name at all on the box. Looks like some local made.
I gave it to my cousin who is a hardware guy. He said that the HDD is not being detected when we connect it to the PC. He even tried with another working HDD inside the External box. He was saying maybe problem with the circuit. He was also saying that there are issues with External IDE to USB HDD converters.
Any guys here who have IDE HDD converted as external HDD?
Old 17-11-2011, 12:39 PM   #15 (permalink)
Fullbring
Zangetsu's Avatar
me...
I had the Zippy Brand used for my internal IDE HDD
Old 17-11-2011, 01:21 PM   #16 (permalink)
ajayritik's Avatar
me...
When did you purhcase for how much and how has it worked.
Well I was planning to buy either an Internal HDD or an external HDD but couldn't since I was very busy when I finally decided to buy one I came to know the prices have gone up so I went ahead and bought this External HDD box which I'm regretting now. I feel lost Rs 550. Have to go back to him and see if he can do something about it.
Old 17-11-2011, 02:02 PM   #17 (permalink)
Fullbring
Zangetsu's Avatar
I bought it in 2011 but month I forgot...
from primeabgb
it has worked flawlessly..
Old 17-11-2011, 02:23 PM   #18 (permalink)
ajayritik's Avatar
from primeabgb
Price? More details about the dealer/shop/online?
Old 17-11-2011, 04:16 PM   #19 (permalink)
Fullbring
Zangetsu's Avatar
it was 750 @ that time..
u can get the price by calling to primeabgb
more info here Prime ABGB Today's Cool Deal!
Old 17-11-2011, 04:57 PM   #20 (permalink)
ajayritik's Avatar
^^ IDE or SATA?
Can you give more details about the internal HDD's that you converted to external.
I'm unable to find External HDD box in the link you gave.
Old 17-11-2011, 05:37 PM   #21 (permalink)
Fullbring
Zangetsu's Avatar
^^ IDE or SATA?
some times they don't give product info on website...for that u have to call them...
it was made for both purpose IDE & SATA...but I connected IDE HDD
Old 17-11-2011, 06:38 PM   #22 (permalink)
ajayritik's Avatar
tu to kamaal hai yaar!
Old 18-11-2011, 03:28 PM   #23 (permalink)
Fullbring
Zangetsu's Avatar
admiring or joking
Old 18-11-2011, 04:14 PM   #24 (permalink)
ajayritik's Avatar
admiring or joking
Obviously praising yaar. I think in some movie Govinda says this.
- by kool
