Old 12-11-2011, 08:43 AM   #1 (permalink)
Question please clear my doubt
hi everyone i have one doubt since i am new to computer my UPS is not working for past 4 days i gave it to service and i am now using without UPS my system gets off due to voltage fluctuation in last 4 day it got turned off in between nearly 100 times i have one doubt when system suddenly gets turnoff due to voltage fluctuation several times whether hardware gets damaged or not within posting this thread my system turn off 6 times please clear my doubt and whether its ok working like that
praveenkumark1990 is offline   Reply With Quote
Old 12-11-2011, 10:30 PM   #2 (permalink)
Default Re: please clear my doubt
No, it's not OK. The component that's most likely to suffer first is the hard disk.
But other parts could also get damaged if power goes on and off so often. Most electrical and electronic products are highly stressed at the moment they are turned on (and sometimes when they are turned off).
And please use punctuations.
pimpom is offline   Reply With Quote
Old 12-11-2011, 10:53 PM   #3 (permalink)
abhidev's Avatar
buddy...due to these fluctuations...i have already damaged 2 hdds...so its advisable to use UPS and spike guard
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is offline   Reply With Quote
Old 13-11-2011, 09:37 AM   #4 (permalink)
ok thanks pimpom
Old 13-11-2011, 09:43 AM   #5 (permalink)
thanks Pimpom and Abhidev.
Got my UPS back yesterday evening.......
Old 18-11-2011, 01:38 PM   #6 (permalink)
i have another doubt whether i should charge the UPS in off or on mode please solve my doubt
Old 19-11-2011, 09:08 PM   #7 (permalink)
BMG ftw!!
d6bmg's Avatar
Mode while charging doesn't matter.
d6bmg is offline   Reply With Quote
Old 22-11-2011, 10:09 AM   #8 (permalink)
Most of the fluctuations must be due to the faulty UPS or probably the battery life is over and it is not retaining charge any more. Working like that could be hazardous for electronic components in your system.
It is advisable to replace your UPS or battery in case you could not get rid of fluctuations even after fully charging it. And yes, whether your UPS is ON or OFF, you can charge it anyway.
susancts is offline   Reply With Quote
- by kool
