Old 11-11-2011, 02:23 AM   #1 (permalink)
Unhappy Computer restarts when voltage fluctuates
hi people.
i have a very big proble, with my computer for past 2 months...
it restarts almost more then 5 times in an hour due to voltage fluctuation...
i bought a new V guard stabilizer and also iball UPS-600v. yet the problem remains...
My system config is
Huntkey SMPS - 600V
2*1 TB HD SATA
1GB NVIDIA Graphics Card
Gigabyte Motherboard
Core 2 Quad Processor
23" Samsung LED Monitor.
i have connected my monitor,speakers and the UPS to the stabilizer. and i have connected the CPS to the UPS......
can someone please give me a solution to solve this problem...
i have a bad power fluctuation problem here...
Please help...
rahulkb is offline   Reply With Quote
Old 11-11-2011, 01:57 PM   #2 (permalink)
Default Re: Computer restarts when voltage fluctuates
1. Check if the earthing thing is intact, or if it is installed at all !!
2. If (1) is 'no' some thing in the mobo could have gotten messed up.
3. Is the electricity department doing some works around the place?
agyaat is offline   Reply With Quote
Old 11-11-2011, 02:00 PM   #3 (permalink)
sriharsha_madineni's Avatar
Are you saying you connected ups to a stabilizer??
If yes, then the time delays of stabilizer & UPS while switching modes, are adding up & hence the chance of restart.
Also, is your home equipped with a inverter/UPS?
[Intel E8400]+[Intel DP35DP]+[4GB DDR2]+[GTX 560Ti]+[Corsair VX450]+[Altec Lansing VS3251R 5.1]+[DELL S2409W]+[Logitech MX-518] [iPod Touch 32GB] [iPhone 4 16GB] [Galaxy S II] [Sony Vaio EB26]
sriharsha_madineni is online now   Reply With Quote
Old 12-11-2011, 08:55 AM   #4 (permalink)
mithun_mrg's Avatar
i doubt its due to the psu/smps can u post what gpu u have
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 12-11-2011, 10:51 AM   #5 (permalink)
digitalpainter
digibrush's Avatar
I had same problem... solved after changing psu.
Intel DH55TC/Core i3 2.93Ghz/corsair Ram(4x2gb1333)/Sapphire HD5670 1Gb/Seagate 1Tb+500Gb/Seagate1TB External/CM Elite 430 & Real power Pro 460W/Creative Audigy+Inspire/iball pentablet/Razer Abyssus//Razer Goliathus/DellST2220L/Windows 7 Ultimate 64 bit.
It's good to touch the green, green grass of home.
digibrush is offline   Reply With Quote
Old 12-11-2011, 06:16 PM   #6 (permalink)
BMG ftw!!
d6bmg's Avatar
Main reason of the problem:
Secondary reasons:
1. Your psu.
2. iBall ups is bad.
d6bmg is offline   Reply With Quote
Old 20-11-2011, 02:32 PM   #7 (permalink)
Your PSU and the iBall UPS are horrible products. Get a decent PSU and all your problems will be solved.
A decent PSU can take voltages between ~100V to ~265V so the fluctuation won't be a problem.
My Sandy Bridge PC :
i3 2100 @ 3.1Ghz, Intel DH61WW, 4GB Corsair DDR3, 2GB EVM(Dynet) DDR3 1333, 500GB Seagate Barracuda 7200.12, Frontech Imagine Case, Hitachi-LG 24X SATA DVD Burner, Corsair CX430 PSU, CM Case Fans.
008Rohit is offline   Reply With Quote
Old 21-11-2011, 04:03 AM   #8 (permalink)
thanks for the comment
what PSU do u suggest for my system's configuration?
Old 21-11-2011, 11:48 PM   #9 (permalink)
BMG ftw!!
d6bmg's Avatar
FSP SAGA II 500W
But first answer: what is the exact modesl of your 1GB nvidia graphics card?
Old 22-11-2011, 03:29 AM   #10 (permalink)
Hey, if you do suspect your PSU to be the fault or find it to be the case, check thoroughly for any physical burns it might have left on the mobo. I lost one of the mobos that way. One of the 4 cpu pins was burnt.
Old 22-11-2011, 03:00 PM   #11 (permalink)
Cool Buddy's Avatar
I think changing the PSU should solve the problem.
Happened often with me when I had a generic PSU. Everytime there was a power cut, the computer would switch off instantly. But when I got Corsair CX400, the problem was solved.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 22-11-2011, 03:38 PM   #12 (permalink)
I had faced the same problem some days ago. Now I am using a UPS and it is working fine.
GPS: The best way to navigate safely and securely.:smile:
rajeevk is offline   Reply With Quote
Old 07-12-2011, 10:00 PM   #13 (permalink)
I suggest a Corsair CX430 V2.
Old 12-12-2011, 03:36 PM   #14 (permalink)
hi guys
thank you all for ur valuable inputs..
i have changed my PSU and system is working fine...
thanks a lot for spending time to solve my problem...
Regards
Rahul
- by kool
