Old 06-11-2011, 09:24 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
avinandan012's Avatar
Unhappy [Problem](s) with 2701 BIOS with M3A78-EM
Any body facing problems using ASUS M3A78-EM(rev.1.03G) with 2701 BIOS & Phenom II x4 955 BE ?
Cause these things are not working Audio Driver & 'Cool & Quite' .
For realtek audio widows says dervice can't start(Error code 10).
For Cool & Quite nothing happens cpu fan runs on 4200+ rpm.
Tried the latest drivers from ASUS.
some digitians have this same setup please respond
avinandan012 is offline   Reply With Quote
Old 06-11-2011, 11:21 PM   #2 (permalink)
Default Re: [Problem](s) with 2701 BIOS with M3A78-EM
latest drivers? you mean latest BIOS?
for slowing down fan, try Q-fan. and also check for audio option in BIOS. it maybe turned off. else reset CMOS.
Old 07-11-2011, 08:24 AM   #3 (permalink)
mithun_mrg's Avatar
Load bios defaults & see which u should do anyway after the bios update also chen the options which sam mentioned in the bios
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 23-12-2011, 10:59 AM   #4 (permalink)
sorry for so late a reply.
^ 2701 is the latest BIOS. When i install the latest audio driver for Win 7 x64
only the HDMI audio is working. Not the 3.5 mm ports(the error says no headphone or speaker is connected).Any help..
tried with BIOS defaults no use
Phenom II x4 955 @ stock with ASUS M3A78-EM (after upgrade BIOS(2701) no AUDIO in Win 7 :x) 4GB DDR2 Transcend, 1TB+2TB, SAMSUNG ext DVD writer, ASUS lightscribe internal DVD Writer, Intex 2.1 sound, NZXT Gamma, CM Excalibur, Corsair TX 850 :twisted:, CM Extreme PowerPlus 600
PHILIPS SHM 1900
Lenovo z570
Steelseries Siberia USB soundcard
Old 03-01-2012, 03:03 PM   #5 (permalink)
any help guys
PHILIPS SHM 1900
Lenovo z570
Old 03-01-2012, 03:18 PM   #6 (permalink)
Hmmmmm
Tenida's Avatar
Try to install some old bios from Asus website for your motherboard.If no success, then format your OS, install the audio driver.If it works then its good otherwise its time RMA your board.Best of luck
Tenida is offline   Reply With Quote
Old 03-01-2012, 05:02 PM   #7 (permalink)
I'll try with some older BIOS.
regarding RMA audio is working fine with Ubuntu.
BTW, can any body throw some light on this sound card
I want a low cost sound card like ^ ,if mobo after BIOS change does not work. performance should match with my onboard Realtec
PHILIPS SHM 1900
Lenovo z570
Old 03-01-2012, 05:39 PM   #8 (permalink)
mithun_mrg's Avatar
^^at least u should get a creative 5.1VX for 1K or the XonarDG for 1.5K even this is better
Zebronics PCI 6 Channel Sound Card with Bill | eBay
Old 05-01-2012, 10:46 AM   #9 (permalink)
How is creative Audigy value ?
which one will be better among these low-cost sound cards
creative 5.1VX or creative Audigy Value?
or going for Asus Xonar DG make sence?
PHILIPS SHM 1900
Lenovo z570
Old 05-01-2012, 03:36 PM   #10 (permalink)
BMG ftw!!
d6bmg's Avatar
Asus Xonar DG will get my vote
d6bmg is offline   Reply With Quote
Old 06-01-2012, 06:14 AM   #11 (permalink)
Fast 'N' Furious
topgear's Avatar
or else OP can try this - it's cheap ( 150- 200 bucks ) but works really well and sound quality is good enough
Convertor
ToPsPeEeD = FaSt BuT StEaDy
Old 06-01-2012, 09:01 AM   #12 (permalink)
^currently i'm using that
PHILIPS SHM 1900
Lenovo z570
Old 06-01-2012, 10:45 PM   #13 (permalink)
BMG ftw!!
d6bmg's Avatar
Convertor
That's a very cheap but useful solution. :w00t:
Old 06-01-2012, 11:45 PM   #14 (permalink)
just now i downgraded to BIOS ver. 2501
let's see if Realtec works or not
fail !!!!!!!!!!
error code 10
PHILIPS SHM 1900
Lenovo z570
Old 07-01-2012, 04:29 AM   #15 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ are you using XP or win 7 ?? Have look at here
Universal Audio Architecture (UAA) High Definition Audio class driver available for Windows Server 2003, Windows XP, and Window 2000
and download and install this :
http://drivers.softpedia.com/get/SOU...on-Audio.shtml
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/148420-problem-s-2701-bios-m3a78-em.html
M3A78-EM 2701 - 楽天ウェブ検索 This thread Refback 26-11-2011 10:49 AM
- by kool
