31-10-2011, 05:46 PM
Wise Old Ghoul
Monitor On/Off problem
I have a Samsung SyncMaster 540n TFT monitor (yeah..its 15.4" only) and is 5 years old.
Now it has started to give problems.Whenever the system does cold start the monitor doesn't gets ON even though the OS has finished up booting.The On/Off button continuously blinks in periodic manner on its own.The monitor gets ON on its own, sometimes it takes 2 mins and sometimes as long as 5 mins!!!
Tell me what should be done.
Regards.
31-10-2011, 05:55 PM
Fullbring
Re: Monitor On/Off problem
if u want a temporary solution then do send it for repair to a local mechanic.
else buy a new LED/LCD monitor bigger than current one
31-10-2011, 06:29 PM
Wise Old Ghoul
yea....was thinking of buying a new one as this one has almost run its course.
But still as this monitor is being used since my first desktop, it feels hard to replace it new one
01-11-2011, 05:37 PM
BMG ftw!!
Emotion?
Looks like that startup button have died. You can try to replace it.
01-11-2011, 06:09 PM
^^ i doubt whether its a button problem
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
01-11-2011, 06:39 PM
Wise Old Ghoul
its not a button problem
I can use it normally when the monitor turns ON successfully
how many chances are there that it is a VGA cable problem?
02-11-2011, 07:19 AM
^^u can give it a try
03-11-2011, 08:00 PM
BMG ftw!!
I highly doubt that.
03-11-2011, 08:11 PM
Wise Old Ghoul
why??
03-11-2011, 08:32 PM
BMG ftw!!
If there were any problem with vga cable, monitor wouldn't have started at all, irrespective of the start-up time. When any problem with cable starts, it disrupts signal flow from motherboard to monitor & thus resulting in complete blackout of that particular monitor.
04-11-2011, 10:01 AM
Fullbring
@Piyush: the problem might be in circuit of the Monitor
04-11-2011, 04:57 PM
Wise Old Ghoul
@Piyush: the problem might be in circuit of the TV.
TV?
You meant monitor...right?
05-11-2011, 09:38 AM
Fullbring
TV?
pardon for the typo...corrected now.
05-11-2011, 07:16 PM
BMG ftw!!
^^ In that case, you should call on a tech person (repair man) to repair your monitor.. But this is an wild guess..
05-11-2011, 08:46 PM
Wise Old Ghoul
hmm will see
first of all i'll check reconnecting and all that common things tomorrow and will post the result
