Old 27-10-2011, 05:08 PM   #1 (permalink)
dharmil007's Avatar
Default Printer Damaged by me ..... need Help
My uncle bought a printer from US 2 months ago.
He bought a converter for it from here. {110V to 230V converter}
iT was working perfectly fine, but one day i mistakely plugged that wire direct into our socket.
& there was a spark after that the printer is not working.
When contacted Epson Customer Care, they told as it is bought from US we dont cover warranty here.
& when contacted service center they told that anything from circuit board to power unit could be faulty.
& if just the power supply is faulty then it could cost upto Rs. 1800 & if circuit board is also gone then price may increase
The Printer bought is : Epson WorkForce 520
The cost of the printer was around $100
So anyOne can pls. help what should i do ??
Does anyone have experienced this before ?
& where should i give this to repair ??
PHENOM II X6 @ 2.8GHz || GA-880GM-UD2H || Kingston 2x2GB Dual-Channel DDR3 || 500GB WDC || Logitech MX518 || Samsung 20" LED SA20A300N
dharmil007 is offline   Reply With Quote
Old 27-10-2011, 07:09 PM   #2 (permalink)
Sage of the Six Paths
Default Re: Printer Damaged by me ..... need Help
Search for a local shop where printers are repaired.
rajnusker is offline   Reply With Quote
Old 27-10-2011, 07:13 PM   #3 (permalink)
Hi Dharmil007,
There is no any other way, you have to change the power unit.
Very rarely, motherboard also may be damaged.
if board also damaged, the best way is try to exchange the printer instead of servicing.
In INDIA, "Epson Stylus Office TX510FN" may alternate for "Epson WorkForce 520" with around the same cost.
I think, all Epson Service centers will service your printer not even in warranty.
You may contact : 1800-425 0011 for Find the nearest service center.
vivekraja is offline   Reply With Quote
Old 27-10-2011, 08:52 PM   #4 (permalink)
dharmil007's Avatar
Hey Thanks buddy
Originally Posted by vivekraja View Post
Hi Dharmil007,
& is it necessary that i have to do it through EPSON, can i do it through local engineers ??
& suppose if only power unit is damaged then u sure it can be repaired ??
what do u mean by exchange ??
i Have to purchase altogether a new Printer & dump this ?
- by kool
