Old 25-10-2011, 12:33 PM   #1 (permalink)
dharmil007's Avatar
Default DvD Writer not working & suggest new dvd writer
i Have Sony dvd writer {SONY DVD RW AD-7260S 1.61).it is reading discs perfectly & writing CDs perfectly. But when it comes to write a DvD, it gives error.i M attaching a ScreenShot of the error, for ur reference.PlS. help me out guyzz what should i do ???
i'VE tried writing different files, but in vain.
i'VE tried using different discs but same error.
i'VE tried using different applications but same error.
This is the new dvd writer which i got replace from the dealer.Previous DVD writer also gave the same error, so i replaced it.
But still the same error.
i Dont know what the problem is, pls help me out guyzz
Previous DvD writer ScreenShot :-
& pls also suggest me a good new dvd writer @ 1000k
PHENOM II X6 @ 2.8GHz || GA-880GM-UD2H || Kingston 2x2GB Dual-Channel DDR3 || 500GB WDC || Logitech MX518 || Samsung 20" LED SA20A300N
dharmil007 is offline   Reply With Quote
Old 25-10-2011, 12:45 PM   #2 (permalink)
Sage of the Six Paths
Default Re: DvD Writer not working & suggest new dvd writer
What types of blank media are you using?
rajnusker is offline   Reply With Quote
Old 25-10-2011, 01:04 PM   #3 (permalink)
dharmil007's Avatar
it can write CDs
but cannot write DvDs
& using Normal dvds
so far checked : Sony, MosearBaer, National
Old 25-10-2011, 01:36 PM   #4 (permalink)
Originally Posted by dharmil007 View Post
it can write CDs
& using Normal dvds
Purchase an ASUS DVD Writer, its the best.
Old 25-10-2011, 03:33 PM   #5 (permalink)
Get an Asus 24x DVD writer @1050.
Old 25-10-2011, 06:59 PM   #6 (permalink)
dvd writer @ 1000 K?!?! anyway, asus dvd writers are quite good, i'm using one myself.
sam1 is offline   Reply With Quote
Old 25-10-2011, 07:58 PM   #7 (permalink)
Dust in the Wind
Skud's Avatar
Even I have heard ASUS ones are good.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 27-10-2011, 11:00 AM   #8 (permalink)
avinandan012's Avatar
I am using an ASUS lightscribe one from January 2007 . It has written near 1000 DVDs & read scrached discs , written about 500 CDs & still going . Only the tray system is malfunctioning now-a-days . But read -write performance is
avinandan012 is offline   Reply With Quote
Old 27-10-2011, 11:26 AM   #9 (permalink)
hiii
if u have any warranty on uvr DVD drive then give to the service centre.
There is a problm in uvr dvd drive lens.
Pawan_Battula is offline   Reply With Quote
Old 05-11-2011, 02:50 PM   #10 (permalink)
Fullbring
Zangetsu's Avatar
@dharmil007: its a new DVD Writer then replace it with the dealer.also do a write check on DVD-RW...
Old 05-11-2011, 03:20 PM   #11 (permalink)
CA50's Avatar
try updating the firmware, else get a LG drive. I have 2 drives working perfectly
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 05-11-2011, 07:23 PM   #12 (permalink)
BMG ftw!!
d6bmg's Avatar
Avoid LG drives.. Stick to Asus DVD writer @1.1K
d6bmg is offline   Reply With Quote
Old 05-11-2011, 07:37 PM   #13 (permalink)
CA50's Avatar
^ sorry mate, i am still using LG drives for more then 4 years, and they still do their work properly
| Nokia 2700c |
- by kool
