Old 25-10-2011, 07:53 AM   #1 (permalink)
avinandan012's Avatar
Default Display Problem
I have ASUS M3A78-EM(rev 1.03G) & Phenom II x4 955 , XFX 9600GT 512MB. CM extreme 600W .
I pc was under my bed for eight months(packed). When i tried to run it last week PC booted & POST properly , but no display was coming from my gfx card. Power is coming from PCI x16 slot, fan of gfx card is rotating(i checked with removing the 6-pin power connector from gfx card). It worked fine from 2008 with Athlon x2 5200+ till march 2011 , then it went under my bed (then i had to travel back & forth to Hyderabad & Kolkata).
current BIOS 2701. But with onboard Radeon 3200 it is working properly. I use a DVI to VGA converter, any chance it went kaput?
What's the problem ?
avinandan012 is offline   Reply With Quote
Old 25-10-2011, 10:28 AM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: Display Problem
Check the RAM. clean it and put it back, also run memtest on it.
once do a complete clean of the system..
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 25-10-2011, 04:06 PM   #3 (permalink)
Just bought a NZXT Gamma & Phenom II 955. I assambled the whole system with cleaning & cable management. After that i noticed the problem.
Old 26-10-2011, 11:32 AM   #4 (permalink)
khmadhu's Avatar
first run memtest for u r RAM, and see if there are any errors..
also try changing the DVI to VGA converter cable. also try connecting it to another port in gfx card (if available).
make sure u assembled u r new CPU correctly.. r u getting any beep sound..?
Old 26-10-2011, 01:00 PM   #5 (permalink)
cleaned the rams with eraser, but still no display
inserted only one stick
is there any chance my pci x 16 slot went kaput?
my gfx card has two DVI & one s-video
i tried connecting to two DVI port - no display
tried the s-video cable with a TV - TV displays no input signal
gfx card is ok i think( the fan is spining on the gfx card when pc is on).
pc boots normally cause i can hear the windows sound
Old 26-10-2011, 01:15 PM   #6 (permalink)
JojoTheDragon's Avatar
Hmmm, maybe you removed the jumper key by mistake while assembling. Check it out please.
Or maybe your dvi to vga converter went kaput ?
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline   Reply With Quote
Old 26-10-2011, 08:02 PM   #7 (permalink)
no the converter is fine works fine in other system
i think the gfx card went kaput
Old 26-10-2011, 10:05 PM   #8 (permalink)
clmlbx's Avatar
try Bios Setting . If your Pci is Disabled or it has setting to select which Display to prefer (It might be preferring 'IGA' instead OF PCI)
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now   Reply With Quote
Old 27-10-2011, 10:18 PM   #9 (permalink)
but when the gfx card is connected no display is coming . Then how do i enter BIOS & change settings ?
Old 27-10-2011, 10:23 PM   #10 (permalink)
Dust in the Wind
Skud's Avatar
Boot through onboard graphics. Go to the BIOS settings and change preferred display to PCI-ex. Also if possible, check your graphics card in another system to be doubly sure.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 30-10-2011, 02:04 AM   #11 (permalink)
Angry Re: Display Problem
bios primary is selected as the PCI x gfx - no problem there
confirmed : the card is dead after 3 yrs of service .checked on two systems . no display is coming but the cooler fan is running. need to buy another one
Old 30-10-2011, 10:33 AM   #12 (permalink)
Dust in the Wind
Skud's Avatar
Sorry to know that. So which card are you planning to get?
Gaming Rig:
HTPC Rig:
Old 30-10-2011, 01:42 PM   #13 (permalink)
clmlbx's Avatar
sad to hear R.I.P Greaphic card . But try showing it to some repairman, might be their is small fault and can repaired which is better then to buy new one.
Old 04-11-2011, 09:06 AM   #14 (permalink)
do you think so ? i'll definitely try the repairman way thanks for the info
- by kool
