Old 19-10-2011, 11:45 PM   #1 (permalink)
mohityadavx's Avatar
Default Connect Desktop HDD to laptop
I am having Dell XPS 15 with eSATA connector in it. Now i wanted to connect my desktop HDD to my laptop so i was thinking of buying an eSATA to SATA cable. My question is but how can i give power to HDD when i want to use it( as it wont run without separate power supply)??
Any alternate method to connect is also most welcome!!!
Come On Guys ! Help Me Out!
XPS 15 | Infibeam Pi |LG P500 |GoGear SA52XX | Sony PS2 | Sony H55 | Sennheiser CX 180 , MX760
For Free Legal Documentation - Rent Agreement/RTI etc
KAGZAAT
www.bleedlaw.com For Law student & aspirant
mohityadavx is offline   Reply With Quote
Old 20-10-2011, 12:10 AM   #2 (permalink)
Sage of the Six Paths
Default Re: Connect Desktop HDD to laptop
You have with you a 3.5" drive right? You need to buy an enclosure, external power source is required to power up the drive.
rajnusker is offline   Reply With Quote
Old 20-10-2011, 01:48 AM   #3 (permalink)
Off for a while.
dashing.sujay's Avatar
There comes a casing for some 300 rs thorugh which you can then use your Desktop hdd as Ext HDD. Same applies for vice-versa, but casing costing some 500.
Sony Vaio CB35-> i5-2430M | 6630M | 4GB | 1080p | Backlit Keyboard
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Drop Box: Get 500MB free
dashing.sujay is offline   Reply With Quote
Old 20-10-2011, 09:17 AM   #4 (permalink)
Thanx but what about the eSATA method its fast
KAGZAAT
Old 20-10-2011, 09:41 AM   #5 (permalink)
Off for a while.
Yup, eSata method will be obviously fast. But i haven't seen anybody using it.
Old 20-10-2011, 10:06 AM   #6 (permalink)
Dust in the Wind
Skud's Avatar
Get an enclosure or a dock. In either case, you need external power source.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 20-10-2011, 11:51 PM   #7 (permalink)
BMG ftw!!
d6bmg's Avatar
Buy an USB to SATA converter for ~300/- and it will do the job for you.
d6bmg is offline   Reply With Quote
- by kool
