Old 18-10-2011, 07:53 PM   #1 (permalink)
Default 12V 1A 2.1mm Power Adapter
My Linksys WAG120N Power Adapter seems to have died as it's not working on either of the ADSL routers I have. Only power LED glows intermittently in both ADSL router. I hope my WAG120N is not dead because connecting the power adapter to other ADSL router resulted in same symptoms but the other router worked fine when powered with it's own adapter.
I need to buy a 12V 1A adapter, what are teh choices I have ? I could find Teking power adapter on ebay india. Not sure if it will work flawless.
Faun is offline   Reply With Quote
Old 18-10-2011, 08:21 PM   #2 (permalink)
Gamer
Default Re: 12V 1A 2.1mm Power Adapter
Maybe your router is short circuited
Gaming Rig:
AMD Phenom II X6 1075T @ 3Ghz | ASUS M5A97 | Sapphire HD6850 1GB | Corsair CX500V2 | G.Skill RipjawsX 4GB @ 1600Mhz | WD Caviar Blue 500GB | ASUS DRW-24B3ST | Dell IN2030M | Logitech MX518 | Cooler Master Elite 311
ArjunKiller is offline   Reply With Quote
Old 18-10-2011, 09:48 PM   #3 (permalink)
well, the point is that using the same adapter, I get the same symptoms in both router (intermittent blinking LED).
Old 26-10-2011, 08:30 AM   #4 (permalink)
mithun_mrg's Avatar
well u can try with a 12V 500-750ma adapter which can be easily found in a local shop
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
- by kool
