Hi Friends,
I purchased a
Dell Inspiron 15r N5010 laptop last year at Rs. 35K(warranty expired in August,28
) and now its started showing problem.
1. Display problem:
I am getting a dark purple/Green color patch at the bottom of screen exactly the size of taskbar(in bios, safemode, windows).
After talking to dell Tech. Support, they told me that its a H/W problem and i need to replace display.
As my laptop is out of warranty they told me upgrade my warranty ( 2 yrs Full accidental cover Rs. 13,000/-
) and this is the lowest price i have to pay to get the problem solved.
They will not repair or check the display, only replacement
2. I am getting a "
Consider Replacing your Battery"massage
Solution from Dell: Replace Battery Rs. 4000/-
Friends please guide me what should i do now??I dont want to pay 13K
Should i approach local technician? Is it safe?I stay in mumbai.
Palying 13k is worth it?
Is there any other better soution on it.
Please reply.
Thank You.
I tried to get image of that dark patch, but print screen not capturing that patch.
