Old 15-10-2011, 10:21 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Smile Will two DDR2 RAMs of different speeds work together on the same motherboard ?
i'm currently using a computer of configuration - 2GB DDR2 RAM , Intel Core 2 Duo E7400 2.8 ghz , Intel DG31PR motherboard , 160 GB hard disk . i want to buy an another RAM in addition to the old RAM . so do i have to buy a RAM of the same speed of that of the old RAM or if i buy a RAM of different speed then will it work together along with the old RAM ?
And my RAM speed is 800 mhz ...can i buy a ram of 1330mhz ? and what is the street price of 4gb ddr2 RAM of 800mhz or 1330mhz in india ?
RockerKG is offline   Reply With Quote
Old 15-10-2011, 10:35 AM   #2 (permalink)
The High 5 Flyer
sam9s's Avatar
Default Re: Will two DDR2 RAMs of different speeds work together on the same motherboard ?
RAM with different speed will work, but the the higher one would work on the low speed. Say you have one 200Mhz and another 400Mhz the 400 one would work on 200 if mixed up. However you can not mix DDR2 and DDR3, though theoretically the difference is in speed, but practically this does not work. Common reason is the Board not accepting both DDR2 and 3
sam9s is online now   Reply With Quote
Old 15-10-2011, 02:10 PM   #3 (permalink)
Adam young
sukesh1090's Avatar
will work but the higher one will be down clocked to the lower as said by sam9s.you better search and get the ram of same specifications of the ram which you are having now.use cpu z take the screen shot of the spd page and post it here.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 15-10-2011, 08:01 PM   #4 (permalink)
JojoTheDragon's Avatar
As said by the others, if you get another RAM with higher speed then it will down-clock itself to meet the slower one and vice versa. So better check your ram speed with CPU-Z and get another one with the same speed.
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline   Reply With Quote
Old 16-10-2011, 07:52 PM   #5 (permalink)
" It'S iN tHe GaMe..."
justme101's Avatar
@RockerKG
every post above mine is correct. Your motherboard description on the Intel website shows that it is capable of DDR2-800/677. {http://ark.intel.com/products/50375/Intel-Desktop-Board-DG31PR}. And it supports a maximum of 4GB you already have 2GB. If it is on one slot then u can get a 2GB DDR2 -800 MHz and put it on the other memory slot. I also upgraded my RAM and had almost the same situation.
BTW i bought a 2GB DDR2 -800 MHz stick for Rs.1500.
Core2Quad Q8400@ 2.66GHZ || INTEL DG41RQ || 4GB DDR2 ZION || SEAGATE 750GB HD || LG FLATRON E2041 20" LED || Sapphire HD6770 || Corsair CX430 V2 || iBALL PIANO 99
Originally Posted by Skud View Post
Congrats Serpent. The joy of holding a new graphics card has no parallel. Enjoy. :doublethumb:
justme101 is offline   Reply With Quote
Old 27-10-2011, 11:12 AM   #6 (permalink)
avinandan012's Avatar
overall speed will be of the minimum speed ram. Try to get rams of same latency like if you have a ram of CL5 ,then try to to get a CL5 ram(s)
avinandan012 is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/147596-will-two-ddr2-rams-different-speeds-work-together-same-motherboard.html
Will two DDR2 RAMs of different speeds work together on the same motherboard ? - Digit Technology Discussion Forum This thread Refback 15-10-2011 12:38 PM
- by kool
