Old 14-10-2011, 06:07 PM   #1 (permalink)
Ayuclack's Avatar
Default PC Wont Start.
I had My Computer Running perfectly fine....few hrs ago...When I Shutdown it and then Restarted it ,,,it Wont Start.....
It Boots,,the Fan Runs but for only half sec and then turns off,,,I have the power light on motherboard glowing...when started using it the same happens and then wont start but the light glows continuously... but when I Press the power switch again it wont even start for a sec and does not responds... the Power Light on the Motherboard is still glowing.
I Am Not Getting any Beep .
My Config are..
CPU- Intel Core i5 2500k with Factory Heat sink.
MB- MSI Z68 GD65 B3
RAm- Gskills Ripjaw X.
HD- 1TB x2
GPU--9600 GT
PSU- Corsair CX 600 V2
Help
Intel Core i5 2500k ||MSI Z68 GD65 B3||Corsair A70:doublethumb:||Gskills Ripjaws X 4GB||Corsair GS 700 :clap2:||Segate Baracuda 1TB X 2 :shock:||Zotac Gforce 9600 GT 1GB HD 7870 Coming Soon ||Coolermaster ELITE 430 :P ||DELL IN 2020||Logitech G 300 :doublethumb:||Logitech Media Combo 200||Creative SBS A335||Tt eSport Shock Gaming Headset White || Xbox 360 Controller
Windows 7:windows:||Mac OS X Lion:apple:||
Nokia 5800 CFW C6 V41||:apple: iPod Touch 4G 64 GB||:apple: iPhone 4 32GB||Samsung Chat 527||PSP 3004 :wow:
http://www.speedtest.net/result/1868396149.png
Ayuclack is offline   Reply With Quote
Old 14-10-2011, 10:27 PM   #2 (permalink)
JojoTheDragon's Avatar
Default Re: PC Wont Start.
Hmmm, a bios reset may help. Remove the battery on the mobo and put it back after 1 min.
Also there may be some hardware damage, but can't say for sure.
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline   Reply With Quote
Old 14-10-2011, 10:33 PM   #3 (permalink)
Ayuclack's Avatar
there is a problem with power supply...its not woking with another pc too...date of purchase 31 aug...going to the service center tomro...would they replace it or repair it....if they replace it..can i get gs600 from them by paying extra bucks....
Old 14-10-2011, 10:37 PM   #4 (permalink)
Sage of the Six Paths
Normally they would replace it. But replacement may take time.
rajnusker is offline   Reply With Quote
Old 15-10-2011, 07:35 AM   #5 (permalink)
Ayuclack's Avatar
I am asking that can i get gs600 instead of cx600 in replacement.
Old 18-10-2011, 11:02 AM   #6 (permalink)
FUBAR.
KDroid's Avatar
^^ I don't think that's possible!
Inactive. For a year.
Twitter
KDroid is offline   Reply With Quote
Old 18-10-2011, 12:47 PM   #7 (permalink)
No, CX is a cheaper PSU. They may do so if you give them extra cash.
Old 23-11-2011, 09:50 PM   #8 (permalink)
@Ayuclack,
have u changed psu? I've similar problem & eager to know ur experience. Please share.
delhiuser is offline   Reply With Quote
Old 24-11-2011, 10:15 AM   #9 (permalink)
Fullbring
Zangetsu's Avatar
@Ayuclack: u wont get another PSU for that in replacement..but do send the PSU for RMA if u haven't done so.
Old 24-11-2011, 07:14 PM   #10 (permalink)
Pro/An---tagonist xD
A same problem happened to a friend of mine. He has a faulty psu. try getting a spare smps to check ur system.
Amd athlon II X3 435 unlocked to Phenom II X4 B35 8-) | MSI 785 G-E53 | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz| Seagate 500 gb 7200.12|
Jripper is online now   Reply With Quote
- by kool
- by ax3
