Old 13-10-2011, 04:29 PM   #1 (permalink)
Default System works with direct power supply but not through ups ..
I recently faced a weird problem with my friend's system..
The system doesn't turn on when connected to ups. But turns on when direclty connected to the plug point. The ups seems to work well and no problem with it...
Where the actual problem lies and how to resolve it ?
pls help me guys..
Phenom II X6 1055T|Gigabyte 880GM-USB3|Transcend 4GB DDR3 1333MHz| Benq G2220HD|PowerColor Radeon HD5770|Seagate 500GB|Logitech MK250|CM Elite 310|Zebronics Pro 600w|Creative A100 2.1 speakers|LG DVD|
giprabu is offline   Reply With Quote
Old 13-10-2011, 05:04 PM   #2 (permalink)
mithun_mrg's Avatar
Default Re: System works with direct power supply but not through ups ..
post complete config of the pc + ups details also what is the exact problem i.e led & fans status etc
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 13-10-2011, 05:51 PM   #3 (permalink)
How did you test the UPS and concluded that it's working normally?
pimpom is offline   Reply With Quote
Old 13-10-2011, 06:21 PM   #4 (permalink)
Test the UPS with another computer if possible. Use alternate ports on back of UPS. Try keep the battery charged for 3to4 hour and then try again.
Old 13-10-2011, 07:35 PM   #5 (permalink)
JojoTheDragon's Avatar
Test your UPS.
Also you may have accidentally switched off the power button at the back of your UPS(if any) or the SMPS.
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline   Reply With Quote
Old 13-10-2011, 09:27 PM   #6 (permalink)
Adam young
sukesh1090's Avatar
post your complete config buddy.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 13-10-2011, 11:19 PM   #7 (permalink)
^ See Op's sig.
TDF @ Steam
Old 13-10-2011, 11:29 PM   #8 (permalink)
^ He said the problem is with a friend's system, not his.
Old 14-10-2011, 07:52 AM   #9 (permalink)
mithun_mrg's Avatar
Talking Re: System works with direct power supply but not through ups ..
+1 to that
- by kool
- by ax3
