Old 10-10-2011, 07:57 PM   #1 (permalink)
" It'S iN tHe GaMe..."
justme101's Avatar
Question How to get front audio ports working??
So i have a iBall Piano 99 cabinet and a Realtek onboard sound card on an Intel DG41RQ motherboard. The cabinet has two front ports for a headphone and a mic similar to ones on the back but they don't work. I didn't bother till now but i am using Virtual DJ which gives an option to use headphones and speakers to play two different tracks (as on a DJ console). After searching the web i found that i can use those front ports to do so.
So any idea of enabling those front ports ???
Core2Quad Q8400@ 2.66GHZ || INTEL DG41RQ || 4GB DDR2 ZION || SEAGATE 750GB HD || LG FLATRON E2041 20" LED || Sapphire HD6770 || Corsair CX430 V2 || iBALL PIANO 99
Originally Posted by Skud View Post
Congrats Serpent. The joy of holding a new graphics card has no parallel. Enjoy. :doublethumb:
justme101 is offline   Reply With Quote
Old 10-10-2011, 11:39 PM   #2 (permalink)
Sage of the Six Paths
Default Re: How to get front audio ports working??
Yes, this toally sucks have seen this issue with many users.. Anyways here's the solution, enjoy
rajnusker is offline   Reply With Quote
Old 11-10-2011, 10:12 PM   #3 (permalink)
justme101's Avatar
^^ I found this solution while gogling...but the option isn't even there. There is just one check box i.e. the second one shown in the above pic.
UPDATE:
Ok what i figure is that the front ports are on the cabinet and are not connected to the motherboard. So can anyone tell me how to do that??
Old 14-10-2011, 10:35 PM   #4 (permalink)
UPDATE:
MB model?
Old 14-10-2011, 11:15 PM   #5 (permalink)
Adam young
sukesh1090's Avatar
@rajnusker,
thank you for that.now i got my front panel working. rep +1.
@op,
connect the audio pin from the case to the audio pin on mobo.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 15-10-2011, 11:02 PM   #6 (permalink)
justme101's Avatar
@rajnusker
It's Intel DG41RQ (btw it's on my signature too)
@sukesh1090
Glad it helped u ok i'll try to connect the pins now..and let you know how it went.
Old 15-10-2011, 11:22 PM   #7 (permalink)
Your motherboard layout:
W is the Front Panel Audio Header.
Old 16-10-2011, 01:19 PM   #8 (permalink)
kool's Avatar
I've MO: ASUS P5KPL AM/PS and QUANTUM cabinet, which is nw 3 year old, and it has only 4 extra wire naming: phone L, phone R, mic, GND. But dont know where to connect. help me... mine too not working front audio+mic,.
►► ◄◄ :smile::smile:
kool is offline   Reply With Quote
Old 16-10-2011, 01:33 PM   #9 (permalink)
BMG ftw!!
d6bmg's Avatar
^^ refer to mobo manual.
d6bmg is offline   Reply With Quote
Old 16-10-2011, 02:56 PM   #10 (permalink)
@kool Are there only four connectors? :/
Try this (for AC97 legacy):-
AGND = GND
Line out_L = Phone-L
Line out_R = Phone-R
Not sure about the MIC part, try MIC2
Old 16-10-2011, 07:45 PM   #11 (permalink)
justme101's Avatar
@rajnusker
I opened up the case and saw the Front Panel Audio Header ( as in my mobo pic above) are occupied with wires coming from the cabinet audio ports. I couldnt see where exactly they come from due to the drive bays. I tried opening up the other side of the case but it just wouldn't open. So my best guess would be that my pc assembler did connect the ports to the mobo. what to do now???
Old 16-10-2011, 07:53 PM   #12 (permalink)
127.0.0.1
mitraark's Avatar
For GIGABYTE Motherboards usually this is the solution ..
Thanks rajnusker
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is offline   Reply With Quote
Old 16-10-2011, 08:52 PM   #13 (permalink)
BMG ftw!!
d6bmg's Avatar
AGND = GND
Yes, according to two pictures MIC should go to MIC2.
MICPWR is the pin for those headers which requires extra power connection for microphone to work.
Old 16-10-2011, 10:59 PM   #14 (permalink)
kool's Avatar
AGND = GND
OK, going2try this, will tell u result soon. Do it require any s/w also like realtek?
Old 16-10-2011, 11:51 PM   #15 (permalink)
@rajnusker
Gimme a screenshot of your Realtek Audio Manager/Control Center.
Realtek is not the only one making AC'97 codec chips, check your motherboard CD or website for softwares.
Old 17-10-2011, 11:04 AM   #16 (permalink)
justme101's Avatar
@rajnusker
Screenshots attached.
Old 17-10-2011, 01:37 PM   #17 (permalink)
@rajnusker
Download the last drivers and check, your Front Panel connector could be defective.
Old 18-10-2011, 11:18 AM   #18 (permalink)
justme101's Avatar
^^ latest drivers installed including BIOS update...only thing left to believe is the ports are defective; can't be sure until i can get the other side of the case to open.
- by kool
- by ax3
