guys my system spec in my sign.
I want to add my old CRT as second display so that i can monitor load on my system when i was working. Is it possible to add it to the mobo VGA CONNECTOR or i need DVI to VGA cable to connect it to my gpu. As i viewed if i install gpu then my mobo automaticlly disables on board vga display connector so plz help me guys.
wat can i do guys.
__________________ :lol:SE K510i
CM 350
CM Xtreme 460w
ASUS P5G41T M LX E5700 oc to 3.8Ghz
HD5670 1gb DDR5
3gb Transcend DDR3 1333Mhz
Lg DVD-RW
160gb WD SATA
2.1Altech Lansing
You need a DVI -> VGA adapter for a dual monitor setup.
how do i get signals from mobo when gpu is installed.
CM 350
CM Xtreme 460w
HD5670 1gb DDR5
Lg DVD-RW
160gb WD SATA
2.1Altech Lansing
