Old 09-10-2011, 09:43 AM   #1 (permalink)
Pirate Slayer
Cool Comps's Avatar
Default Slight shock from computer USB port
Guys!!!!!!!
Suddenly I realised yesterday my USB ports are giving me a slight shock if i touch them.
Now today i am getting the shock anywhere i touch the metal portions of the case!!
What should i do?
CPU : i5 2500 | Motherboard: Intel DH67BL | RAM: 4 gb corsair vengeance | HDD: 1 tb seagate |
GPU :Sapphire HD 6870 | PSU :Corsair TX650 v2 | Cabinet : CM Elite 430
Cool Comps is offline   Reply With Quote
Old 09-10-2011, 11:39 AM   #2 (permalink)
pulkitpopli2004's Avatar
Default Re: Slight shock from computer USB port
its a common problem.. get the earthing done in your room.. call any electrician...
I'd explain it to you, but your brain would explode... Trust me :hot:
i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB Caviar Black
pulkitpopli2004 is online now   Reply With Quote
Old 09-10-2011, 11:40 AM   #3 (permalink)
Check your earthing. In 99.9% of cases, this is not due to any defect in the system, but due to normal leakage in the PSU, UPS and spike guard.
The PSU etc have built-in filters against voltage spikes and EMI. These filters provide slight leakage paths to the cabinet metal which is supposed to be connected to ground. If the system is properly grounded, the leakage currents flow harmlessly to ground (earth) via the house wiring.
The problem is that the wiring in many buildings don't have proper earth lines. Therefore, when you touch any metallic part of the system, the leakage currents flow through your body and gives you a shock.
If your body is dry, the shock is mild and normally not dangerous. But if your body is damp, e.g. when you're sweating or if you've just finished having a bath, then your body's electrical resistance is much lower and the shock can be very unpleasant or even dangerous.
The solution is to have a properly grounded wiring.
pimpom is offline   Reply With Quote
Old 09-10-2011, 12:53 PM   #4 (permalink)
^^^^^^+1 it earthing problem or check ur main CPU connector which is connected to ur mains and the PSU sometime it due to the wire
Athlon II X4 640||GigaByte 78LMT-S2P||Corsair 4GB DDR3 1333Mhz+ 2GB EVM DDR3 1333Mhz||VIP 400watts PSU||Sapphire 5670 930/1020:P|| Philips 107E5 1280x1024 17''CRT|| Zebronics Bijli mod
http://www.hardfolding.com/fhtag.php...451114/1/4.png
Tarun is offline   Reply With Quote
Old 09-10-2011, 04:34 PM   #5 (permalink)
Pirate Slayer
Cool Comps's Avatar
BTW My Cabinet stands on a wooden platform. Can it be that the leakage isnt being transferred?
Also, I dont know whther its an earthing issue. But i found out that if i switch on the socket and then the UPS, a green led glows on my Mobo. And already there is shock on my case. Any further ideas. Yes ill be calling my electricin. However if he says that electric ports aare fine, will he be able to point out the problem or will i have to point it out myself(or call an engineer)
Old 09-10-2011, 06:44 PM   #6 (permalink)
read pimpom's post once more. its about the earthing. not where your cabby is kept. it may happen if the earthing wire is broken to that particular socket or the earthing was not done properly when the electrical work was carried out.
Old 09-10-2011, 06:53 PM   #7 (permalink)
In my case, if i touch the metallic portion wearing a slipper, i won't get any shock, but with bare foot i get shock. what does this mean? If it was a earthing problem i should get shock even while wearing slippers, right?
casual_gamer is offline   Reply With Quote
Old 09-10-2011, 07:18 PM   #8 (permalink)
Ever wonder why birds perching on high tension cables do not die out of shock ?
because they wear slippers made of dry/non-ionized air
Faun is online now   Reply With Quote
Old 09-10-2011, 07:36 PM   #9 (permalink)
iGoogle
guru_urug's Avatar
@OP
Do this:
1) Try using another spikeguard and check if prob is gone
If you dont have another spikeguard then directly connect the PSU power cable to the wall socket, power on the CPU and check if there is still any voltage leakage (preferably with multimeter). If the problem is no more, then culprit is spikeguard, get a new one!
2) Incase there still is, then try using another wallsocket (preferably of another room. Check if the problem goes. If it does, culprit is the earthing in your room
3) If possible get another PSU from a friend and start your PC with it and check if the problem goes. If it does then culprit is PSU, get a new one!
If problem still persists then there is only one possibilty, the earthing in your house is faulty, call an electrician and get the problem fixed ASAP
AMD Athlon II X4 630 | MSI 785GM E51 | 4 GB DDR3 1333 Corsair | 500+160 GB Seagate | SAPPHIRE HD 6850 :2subs: | NZXT Gamma | Seasonic 500 Watt :D | Samsung 19" LCD | LG optimus one
guru_urug is offline   Reply With Quote
Old 09-10-2011, 09:58 PM   #10 (permalink)
This issue has come up several times before, so I prepared the drawing below a few years ago to illustrate how it works, but I never got around to uploading it until now. I hope it will help.
@casual_gamer: Look at the picture. See how the leakage current flows through your body and out to ground through your feet. If you're wearing rubber slippers, they block the flow of current. But this is only if your slippers are good electrical insulators and are dry.
Old 09-10-2011, 11:25 PM   #11 (permalink)
a_g = JPKN
s18000rpm's Avatar
Do you have any Chinese or local make speaker system or similar stuff connected to your PC?
Remove all such connections and check.
I once had similar problem, only diff was my PC was transferring 240 volts to USB Ports, CRT monitor (shock on glass).
I thought there could have been earthing issue, our psu gone wrong, I checked up earthing, bought a new psu cooler master, but still got the shocks, then finally removed a local make 5.1 system connection, that bloody thing was leading current into the PC via 3.5mm cables.
ASUS K53SV SX520D + BF3
s18000rpm is online now   Reply With Quote
Old 09-10-2011, 11:51 PM   #12 (permalink)
Super Moderator
asingh's Avatar
@Pimpom:
Really nice.
asingh is online now   Reply With Quote
Old 10-10-2011, 01:09 AM   #13 (permalink)
Pirate Slayer
Cool Comps's Avatar
The problem turned out to be with my spike buster. One of the earthing pins on it was loose so at times it was cutting off the earthing. My electrician told me that. I had another Spike buster(which i had bought from MD when i bought my rig but i hadnt used it). So i started using it. I also kept his tester. ANd There isnt any shock now.
BTW Can Your keyboard or mouse also shock you? Coz i feel a slight buzz in my fingers at times when using them. Now this can be my imagination or it can be since its quite late int he night. But just wanted to know.
Old 10-10-2011, 02:16 AM   #14 (permalink)
BMG ftw!!
d6bmg's Avatar
@pimpom: nicely explained with pic.
+1 rep.
d6bmg is offline   Reply With Quote
Old 10-10-2011, 02:48 AM   #15 (permalink)
Have you been having wet weather? Moisture on the mouse and keyboard can allow enough current to flow on them to give a slight tingling or buzz, especially if they are not perfectly clean. The accumulated dust and dirt absorbs moisture from the air. Even if the plastic surfaces look dry and reasonably clean, microscopic amounts of dust and moisture can get trapped there.
Also remember that no material is a perfect insulator. The plastic body of your keyboard and mouse can pass tiny amounts of current. Normally, such currents are too small to be felt. But they may be noticeable under certain conditions. Another factor is that different people have different levels of sensitivity.
Old 10-10-2011, 06:36 AM   #16 (permalink)
Never give up!!
jerrin_ss5's Avatar
very good explanation pimpom
i may sound naive but please help me as i am weak in electricals
but orange is ac and black i presume is ground so the leakage current should go through black wire na
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 10-10-2011, 09:30 AM   #17 (permalink)
a_g = JPKN
s18000rpm's Avatar
That's earthing problem. Get the sockets checked again. Buy a Belkin spike buster.
Old 10-10-2011, 10:15 AM   #18 (permalink)
most common assumption is earthing must be faulty first call electrician or take a multimeter and check earthing at socket if it is fine then something is wrong with the appliance, even in my house we have weird problem when the heater is swithched off sometimes in bathroom i get shock, called electrician and he checked earthing , heater etc and all is fine, now the shock is coming only morning during -6.30 to 07.00 am for some 10-15 mins not at all times so electrician told that someone must be using some faulty appliance, then had to tell neighbours about ti and guess the stupid neighbour stopped using his faulty appliance, probably an IRON ,,, but still electricity is hard to understand inspite of fauly appliance earthing should go via earth to ground and not shock the person,, dont know im not engineer tap in bathroom gave strong shock, and i am even today afraid but since electrician checked n certified strong earthing i need to only worry about neighbours, if the shock that ur getting is only sometimes and repeats only at specific times then it might be due to some faulty appliance used by somenoe in ur home
rsk11584 is offline   Reply With Quote
Old 10-10-2011, 11:32 AM   #19 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
Brings back the memories of my old days. There were times, where, I was afraid to even go near my cabinet.
Anyway.. as the other members are pointing it out, it is clearly the grounding problem. Make sure that the socket is properly grounded. You will be good to go.
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is offline   Reply With Quote
Old 10-10-2011, 11:51 AM   #20 (permalink)
abhidev's Avatar
try using a 3-pin plug if you are using 2-pin plug...
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is online now   Reply With Quote
Old 10-10-2011, 04:34 PM   #21 (permalink)
is it okay for the computer hardware if earthing is not done? i have ups and spike guard, will my hardware get damaged?
Old 10-10-2011, 05:58 PM   #22 (permalink)
Pirate Slayer
Cool Comps's Avatar
My earthng is fine. And I tested using tester on my keyboard. And after the elctrician came i havent even got a shock form my keyboard. So i assume it was my imagination of my fingers getting buzzed by the keyboard and mouse. HAHA LOL
- by c4u
