Old 04-10-2011, 10:53 PM   #1 (permalink)
rajivnedungadi's Avatar
Default Memory Dump Error on 3 day old system
I purchased a new system 3 days ago. I have been getting the blue screen of death or the memory dump screen ever since I assembled it and installed Windows 7 - 64 bit. How to check what is going wrong?
System config
Intel i5 2400 CPU
Gigabyte Motherboard
8 GB (2 X 4 GB) Transcend DDR3 RAM - 1333 MHz
2 TB WD HDD
Blu Ray Writer
OS Installed - Windows 7 - 64 bit
Movie Databases: Free Download: http://www.4shared.com/dir/rjI50qqm/Databases_2010.html
http://shop.ebay.in/merchant/taurusoft.india
rajivnedungadi is offline   Reply With Quote
Old 05-10-2011, 03:37 AM   #2 (permalink)
MegaMind's Avatar
Default Re: Memory Dump Error on 3 day old system
Which PSU, mobo model, GPU(if any)?
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 05-10-2011, 03:47 AM   #3 (permalink)
The Grahics card is Asus Nvidia GeForce 520 GT (1 GB DDR3)
Motherboard, I will check and get back
Old 05-10-2011, 03:52 AM   #4 (permalink)
MegaMind's Avatar
Also the PSU/SMPS...?
Old 05-10-2011, 09:17 AM   #5 (permalink)
Check if you have fitted everything properly. Refit the RAM especially because even I have had BSOD errors due to non proper fitting of it
Old 05-10-2011, 07:10 PM   #6 (permalink)
The SMPS is Cool Master 350 Watts
Gigabyte H61M S2P B3
I will do that....I also ran the memcheck to check the RAM and it showed no errors
I have done a system restore and installed only the drivers required but it still reboots
Old 06-10-2011, 07:51 AM   #7 (permalink)
i think your 350 watts smps is not enough for such a powerful config. try running the pc without gpu, without blueray and with 4gb ram. that's the maximum you can tone down, if the pc runs well, then you know the problem.
casual_gamer is offline   Reply With Quote
Old 06-10-2011, 11:51 PM   #8 (permalink)
It works well in safe mode, I kept it on in safe mode for more than 8 hours and it never rebooted
I have now disconnected the belkin network adaptor and some other drivers that I feel might be causing the issue....Let me check if that is the case
I think I have found the solution but I need to confirm it. I had connected a Belkin USB wireless adapter, I disconnected it and tested it for 3 hours and it did not crash. normally it crashes within 2 hours. I also left it in safe mode for 8 hours and it did not crash, therefore I realised that it is some hardware drivers causing the issue. I check it and you guys know about the status. thank you for your helo and suggestions
Old 07-10-2011, 12:09 AM   #9 (permalink)
Super Moderator
asingh's Avatar
If you getting any memory dumps, post them on a link. I can look at them.
asingh is online now   Reply With Quote
Old 09-10-2011, 01:09 AM   #10 (permalink)
Thank you. Its been resolved! updated the belkin usb wireless adapter drivers and it has been working fine for the past 2 days now...
- by c4u
