Old 04-10-2011, 12:55 AM   #1 (permalink)
Default PC not starting -detail posted
My Dads PC is not starting , unable to find cause of the problem , pls help
COnfig
P5KPL-AM/PS
P4 2.8Ghz
4GB DDR2 Ram
150GB PATA H.D
450 W Zempronic
1) All Fans , LED, H.D's ON
2)Keyboad LED,Mouse LED , MOnitor OFF
3)SMPS fan, system fan running
4)Not even entering BIOS or any BEEP signals
1) i tried remove 1 of the ram and chked -not working
2)changed PCI-E card to integerated and tried -not working
3)Connected PATA H.D to my main rig and did scan disk - no error , SMART -OK
4)Did full cleaning carefully also reapplied TIM
5)
Usage - Just for Billing - no Resource hungry applications just pure Accounting only
Can any1 give me a hand pls
AMD Phenom II X6 1055T ,Benq G2220HD 22 ,GIGABYTE GA-880GM-UD2H ,COOLER MASTER Elite 310 ,CORSAIR 2GB 240-Pin DDR3 X3[6GB] , FSP Saga II 500 W HD 5750 . Hyper 212+ OS :Win 7 64 bit
Rajesh345 is offline   Reply With Quote
Old 04-10-2011, 04:01 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: PC not starting -detail posted
Try removing the CMOS battery ( the big coin sized battery on mobo ) and put it back again properly after couple of minutes.
ToPsPeEeD = FaSt BuT StEaDy
Old 05-10-2011, 09:37 AM   #3 (permalink)
1) Removed and putted bk after 2 minutes - Worked
When shutdown it hanged so shutdowned with power button > when i tried start again same problem , But NOW it started working again -_-
ty
Old 06-10-2011, 03:11 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ glad to know it's working now
it's looks like a ram issue - test your rams with memtest app to be sure.
- by c4u
