Old 02-10-2011, 11:18 PM   #1 (permalink)
Question New Graphics Card
Hi, I was thinking of upgrading my Graphics card.
I'm currently running Intel Core 2 Duo E7500 2.93GHz, with Intel DG41RQI motherboard and 2GB + 2GB DDR2 RAM.
With ATI Radeon 4770 HD Card I got more than 1 and half years ago.
I wanted to upgrade my Graphics card and was thinking of
MSI N 550GTX- Ti Cyclone II 1GD5/OC
http://www.msi.com/product/vga/N550GTX-Ti-Cyclone-II-1GD5-OC.html
. It appox costs Rs.9.5K
OR
XFX ATI Radeon
http://xfxforce.com/en-gb/products/GraphicCards/HD%206000series/6790.aspx
. It appox costs Rs.9.2K
My price range is <12K and it should be obvious upgrade over old card.
So which card would you suggest?
Also I wanted to know should I stick to XP OS or upgrade to 7 OS for new card? As my main intention of getting the card is to also play Battlefield 3.
And I'm keeping option open to buy online. So you can suggest links if any!!
Nin13 is offline   Reply With Quote
Old 03-10-2011, 06:13 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: New Graphics Card
^^ which PSU do you have ??
Under 12k the best deal you can get is HD6870 Hawk - it's worth the money you pay for it and upgrade to windows 7
ToPsPeEeD = FaSt BuT StEaDy
Old 03-10-2011, 02:38 PM   #3 (permalink)
Please post your PSU details. And yes the 6870Hd is the one to get.
Old 03-10-2011, 06:53 PM   #4 (permalink)
PSU is iBall Sprinter 500, Maximum Output = 500W.
what if I have to choose between MSI N 550GTX- Ti Cyclone II 1GD5/OC and XFX ATI Radeon 6790 HD?
Also i checked an online site which sells cards, they have foll option for 6870 HD
And 1 in particular to go for
- Sapphire Radeon HD6870 1GB ATI
- Asus Radeon HD6870 1GB DDR5 ATI PCI E Graphic Cards (EAH6870-2DI2S-1GD5)
- Power Color Radeon HD6870 1GB GDDR5 ATI PCI E Graphic Cards (AX6870 -1GBD5-2DH)
- Sapphire Radeon HD6870 Flex Edition 1GB DDR5 ATI PCI E Graphic Cards
- Sapphire Radeon HD6870 1GB (Vapor Edition) ATI PCI E Graphic Cards
- XFX Radeon HD6870 1GB DDR5 ATI PCI E Graphic Cards (HD-687A-ZNFC)
Old 04-10-2011, 12:22 AM   #5 (permalink)
MW3>BF3
abhinavmail1's Avatar
First upgrade your psu. Buy fsp sagaII 500w for 2k and msi r6850 oc/pe for 10k
Athlon X3 445 |corsair 2X4gb ddr3 1333mhz | Fsp sagaII 500 | CM 310 | Asus M4A78LT-M LE | Sony ODD| segate 500gb HDD| Dell IN 2020M (1600X900) | Segate 500GB External | Nokia X2-01 |Gigabyte 5770|SkullCandy INK'D|Bajaj Discover 100cc | BSNL750ULD
abhinavmail1 is offline   Reply With Quote
Old 04-10-2011, 03:05 AM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
Don't get XFX and for PSU you can take a look at Corsair VX430v2 @ ~2.3k.
Old 06-10-2011, 03:26 PM   #7 (permalink)
Originally Posted by topgear View Post
Don't get XFX
ANy specific reason not to??
Old 07-10-2011, 02:55 AM   #8 (permalink)
The only output which you will get at 500w load with this PSU is smoke. Replace it with something reliable.
You are actually lucky that it has lasted you this long with a graphic card like HD 4770.
Old 07-10-2011, 02:56 AM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ just go through these threads and you'll know the reason :
the RMA experience thread
The Rashi RMA experience thread
Old 08-10-2011, 10:00 PM   #10 (permalink)
But I'm not buying from Rashi Peripherals. I'm ordering online via www.theitdepot.com because place where I leave (Goa) there are no good shops to buy PC stuff so such things have to be brought online.
Old 09-10-2011, 04:19 AM   #11 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ if ordering online is your only option then why not opt for some other brand ??
here's a good online shop you can have a look
SMC international
Old 12-10-2011, 04:44 PM   #12 (permalink)
You could have a look at this -
Graphics Card
MSI R6790-2PM2D1GD5
Power Supply
TheITWares - One Stop for all Gizmos!CORSAIR Builder Series CX600 V2 600W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
Where in Goa are you from my Friend?
let us all see the "i" in the "u".
insaneYLN is offline   Reply With Quote
Old 13-10-2011, 03:43 AM   #13 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ I think by paying 450 bucks more Op can get Corsair GS600
for <12K Op can get HD6850 Cyclone Power Edition @ 9k and FSP Saga II 500/Corsair CX430v2 @ 2.3k
Old 13-10-2011, 04:11 PM   #14 (permalink)
Thanks guys for all the help. Will let you know what card I guy!!
- by c4u
