Old 30-09-2011, 07:08 AM   #1 (permalink)
SuperMASSiVE
stonecaper's Avatar
Default Suggest a UPS & a CPU Cooler
Requirements -
For UPS - Just Should be able to handle the power surges.actually my room is connected to our inverter but in times of heavy load it fails to switch to battery properly.so my PC stops abruptly,No Signals On LCD,CPU Runs But without any activity.
I Know How Dangerous it is,already lost partitions of My WD 1TB.
For CPU Cooler - Should Be Easy to install and be able to Keep my CPU temp ~45 degs at full load
For Both - Should Be Cheap as possible (Loads of puja Shopping Done already ) and should be easily available (Read - Available online)
Steve Jobs (February 24, 1955 – October 5, 2011) & Jagjit Singh (8 February 1941 – 10 October 2011)
RIP
stonecaper is offline   Reply With Quote
Old 30-09-2011, 07:38 AM   #2 (permalink)
Default Re: Suggest a UPS & a CPU Cooler
For UPS,
Go for Intex 1 Kva @rs.1800
I donot think there is need for a Cpu cooler unless you Overclock
Old 30-09-2011, 07:57 AM   #3 (permalink)
mithun_mrg's Avatar
or op can go for a cheap TX3 @1.2K
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 30-09-2011, 09:27 AM   #4 (permalink)
+1 for thetechfreak u really dont need a CPU cooler if u ain't OC 24/7 try refitting the current cooler and apply a AS5 or MX-2 Thermal paste which will reduce the tem by over 15c atleast it did mine on my E2180,E7200,Athlon II X4 640
yet u want to go in for a cpu cooler a 212+ is a solid cooler it may cost u 1.9k but its worth it and keep in mind u get the hell out of u Athlon II X4 630 but still the temps will be in controls or as a cheaper option is always a TX-3
Tarun is offline   Reply With Quote
Old 01-10-2011, 07:23 AM   #5 (permalink)
SuperMASSiVE
stonecaper's Avatar
Originally Posted by thetechfreak View Post
For UPS,
Actually the temp reaches ~60 when i am playing shift 2.
Dont wanna Take any chances so.
of course i will try refitting
Also will the intex UPS handle Random power Surges.I need the UPS only for that Purpose..
Lastly TX3 or 212 Guys??
RIP
Old 01-10-2011, 07:44 AM   #6 (permalink)
mithun_mrg's Avatar
212 if ur budjet permits
for ups u can consider APC 650VA also @2K
Old 02-10-2011, 02:48 AM   #7 (permalink)
BMG ftw!!
d6bmg's Avatar
CPU Cooler: CM Hyper 212+ without any second thought.
d6bmg is offline   Reply With Quote
Old 12-10-2011, 12:32 AM   #8 (permalink)
avinandan012's Avatar
+1 for APC .
Dont go for intex(good battery but bad electronics) . Get the APC [@p.f. of 0.7~ 650*0.7=455].
No need to look further get the 212+ & add another fan in PUSHPULL config it will match(well you can compare) the CM N620.
avinandan012 is online now   Reply With Quote
Old 12-10-2011, 02:02 AM   #9 (permalink)
find a hyper 212 EVO if u can or a 212+ will do and go for a APC UPS
Athlon II X4 640||GigaByte 78LMT-S2P||Corsair 4GB DDR3 1333Mhz+ 2GB EVM DDR3 1333Mhz||VIP 400watts PSU||Sapphire 5670 930/1020:P|| Philips 107E5 1280x1024 17''CRT|| Zebronics Bijli mod
http://www.hardfolding.com/fhtag.php...451114/1/4.png
- by c4u
