29-09-2011, 02:31 PM
#1 (permalink )
suggest SMPS
please suggest SMPS for PC
Config:-
AMD X6 1055T
880 gigabyte
4GB ddr3 RAM
1TB HDD
ATI 6750 1GB
can i run this using normal 250 watt SMPS or shuld i have to buy a new SMPS??
pease suggest compny nd price also if possible...
Thank u...
29-09-2011, 03:26 PM
#2 (permalink )
Re: suggest SMPS
Please change your SMPS to a good SMPS. A normal 250 watt may fry your computer.
Go for Corsair GS600 . Cost is around 3.8K (not sure).
29-09-2011, 03:56 PM
#3 (permalink )
Dust in the Wind
Re: suggest SMPS
Corsair CX430V2 should suffice for your config.
Gaming Rig:
Spoiler :
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 ||
Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
Samsung Galaxy R I9103
Will be off/irregular for a month...
29-09-2011, 04:05 PM
#4 (permalink )
Re: suggest SMPS
@sumsave
+1 and it is not
it WILL FRY.
Go for a good PSU as suggested and also pls read the dedicated thread reagrding the PSU in this forum.
29-09-2011, 04:09 PM
#5 (permalink )
Gamer
Re: suggest SMPS
Cooler Master eXtreme 500, been using it for 1 year for my 6850 and core i7, no problems til now.
29-09-2011, 04:36 PM
#6 (permalink )
Whompy Whomperson
Re: suggest SMPS
Originally Posted by
ArjunKiller
-100 for CM eXtreme!!
Better to change the PSU or you will have to edit your post soon and will have to write "Dont go for it"
29-09-2011, 04:52 PM
#7 (permalink )
Re: suggest SMPS
hehe
Arjun Killer get rid of it AS SOON AS POSSIBLE before it kills your rig.
i7 with CM EXTREME 500
29-09-2011, 04:54 PM
#8 (permalink )
Re: suggest SMPS
Nipun
Agreed. Do not go for CM extreme. They are the worst PSU ever made my CM.
29-09-2011, 06:01 PM
#9 (permalink )
Re: suggest SMPS
ArjunKiller
a few members suggest what they are using without giving a second thought if the product is good or better alternates are there.
even a local 500W will be able to handle OP's system, till it goes up in smoke causing hdd, GPU failure, etc.
29-09-2011, 06:09 PM
#10 (permalink )
Fullbring
Re: suggest SMPS
sumsave
250 watt is too low for the u have listed....
get SMPS from a reputed brand such as Corsair,CM,Seasonic,FSP etc
how much is your budget?
29-09-2011, 06:10 PM
#11 (permalink )
Hmmmmm
Re: suggest SMPS
FSP saga 500 watt or Corsair CX430 V2
01-10-2011, 12:15 PM
#12 (permalink )
Re: suggest SMPS
my budget is lyk 1.5k-2k around...
do i have to add another supply for HD 6750??
01-10-2011, 12:56 PM
#13 (permalink )
Fell Off the Asembly Line
Re: suggest SMPS
sumsave
Just get a FSP saga 500w @2.2k for your config, and you don't need other psu for your gpu.
01-10-2011, 01:09 PM
#14 (permalink )
Re: suggest SMPS
sunny4691
but somewhere i heard that i need GPU for 6750 and not for 6670...is this rite what i heard???
01-10-2011, 01:42 PM
#15 (permalink )
Off for a while.
Re: suggest SMPS
sumsave
i guess you mean PSU, mistyped GPU.
01-10-2011, 02:22 PM
#16 (permalink )
Re: suggest SMPS
dashing.sujay
yeah re...sorryy...bt wat i heard is rite ?
01-10-2011, 07:07 PM
#17 (permalink )
Off for a while.
Re: suggest SMPS
sumsave
No its not right. Its always to get a good PSU/SMPS if you have a dedicated gfx card. Go for the suggestions above. FSP saga II 500w Or Corsair VX430v2
01-10-2011, 07:54 PM
#18 (permalink )
Whompy Whomperson
Re: suggest SMPS
sumsave
By another PSU do you mean separate PSU? No. Get FSP Saga II 500W as others are suggesting and use it to power all your system..
01-10-2011, 11:30 PM
#19 (permalink )
Re: suggest SMPS
thank u guys for advice...
02-10-2011, 12:23 AM
#20 (permalink )
Sage of the Six Paths
Re: suggest SMPS
A good 500W is more than enough for that rig.
02-10-2011, 06:00 AM
#21 (permalink )
Fast 'N' Furious
Re: suggest SMPS
sumsave
Cards like HD6750 requires a separate power connector which every good branded PSU comes with and you will get a pci-e/molex power converter with the card box as well - just use the 6 pin pci-e power cable and fit it into the appropriate pci-e power connector of the HD6750
HD6670 consumes less power than HD6750 and the pci-e slot on the mobo is enough to power this up - so you don't have to use any additional power cable with cards like these
