Hello,
My laptop : HP pavillion tx1003au tablet
Warranty : Over
Already purchased : New battery and new adapter ( charger )
Already Done : 3 Full format
1. Vista itself
2. windows 7
3. Windows xp
everything is fine in device manager
Problem:
1. On turning the laptop on , only the lights come up , i dnt even get the hp logo many a times , i can hear d fan and processor.. nothing happens till battery dies.. Sometimes if u r lucky the laptop boots and works fine
2. The laptop does not detect any WIFI CARD DEVICE ( as if dere is no wlan in my lappy )
I tried everything at my level , here is wat i got in d end , my lappy wlan card works in my friend`s lappy but my friends`s card does not work in mine and hence i concluded dat dere is no problem with the wlan card
RAM, Hardisk is fine >> did all diagonistic test for problem 1
battery and charger are new
What can the problem be ??
If motherboard , what is to be done ? its a lappy ?? i dnt wanna shell out much money
Need to get this sorted asap
Regards
